Stock Radio-amp
Old Feb 20, 2003 | 10:35 PM
OZ_Chic's Avatar
Talking All wired
Here are my subs... 2 10" JLW0 in a bandpass box.
Old Feb 24, 2003 | 11:26 AM
Higgity Hank's Avatar
Originally posted by cupOZnj
in line convertor probably works a little better since RCAs have better RF blocking qualities than speaker wire.
Apples and oranges man... Speaker wire doesn't need the RF sheilding because it's a high level signal, far less likely to absorb anything. RCA's have the sheilding because they're only pushing a small amount of current through small wires, and in the automotive environment that spells signal problems.
It really comes down to a 6 of one half-dozen of the other situation. Line level converters have a bad rep behind them, and for good reason most of the time. They're usually made relatively poorly, and act as such. High level inputs on the amp is probaby easiest/cheapest way to go in this situation.
Old Feb 24, 2003 | 01:27 PM
cupOZnj's Avatar
yeah, that's a good point.
Old Feb 24, 2003 | 08:19 PM
neilschelly's Avatar
probably not. aftermarket head units are made to be universal. i doubt you are going to find one that fits in perfectly without the little trim piece that goes around it to cover up the hole.
I just installed my stereo from my old car last night, a 1998 Blau Las Vegas. It's not an exact size fit because of the wider and slightly taller face on the Lancer's head unit, but it's definitely flush mounted.
At least in this case, that trim around the stereo is only connected by thin strips of plastic intended to be cut for flushmounting. There are two sets of holes on the side of an ISO DIN unit and with a little drilling in the brackets that came with your Lancer unit, you'll easily have a flush mounted unit.
-N
Old Feb 26, 2003 | 12:45 PM
YouNVthis's Avatar
yea thats another good point
jake92695
Jul 15, 2017 01:00 PM
evolution91
May 16, 2017 01:40 AM
blancoloco
11
Oct 10, 2016 04:16 AM
mines5
Sep 28, 2016 01:27 PM
Dragking2189
15
Mar 29, 2009 04:47 PM
