Mounting amp on back seat
Old Feb 27, 2003 | 04:12 PM
crusin_lancer's Avatar
Well I searched and couldn't find nothing. I want to mount my amp on the back seat. Is there Some wood between the metal bars? I was going to use 1"scews for it but was sure if there was wood between those bars? How did some of you do it?
Old Feb 27, 2003 | 04:21 PM
nightrider's Avatar
i mounted mine back there. just screww em i had no problems. i dun know the size of the screws but 1 inch should be good.
Old Feb 27, 2003 | 04:36 PM
cleofis's Avatar
hmm..i had the same problem kind of. did you guys use a drill to get the screws in or did you just start screwing them into the metal?
Old Feb 27, 2003 | 04:40 PM
LBLancerDude's Avatar
use velcrow man... thats what i did and the amp is snug as a bug
Old Feb 27, 2003 | 04:41 PM
cleofis's Avatar
genius. i never would have thought of that
Old Feb 27, 2003 | 04:47 PM
yeah just make sure u get alot to cover more than 1/2 the surface area... and uh... i dunno how it would work for really big heavy amps
Old Feb 27, 2003 | 05:05 PM
Nero's Avatar
man for me it was alot better making an amp rack. when i had my amps mounted on the back seat it was a pain in the ***. pulling the carpet up and cutting it wasent worth it to me. there was a big lump under the carpet from the 0 ga power wire. a small amp rack is alot more practical i.m.o..... otherwise i just screwed directly into the metal under the carpet.
also depending on the size of your amp u could mount it on top of a flush mounted wooden block in that little square indention behind your tail light.
Old Feb 27, 2003 | 05:38 PM
OZ_Chic's Avatar
Yeah mine is mounted on my backseat too! Its easy...no problems with it
Old Feb 27, 2003 | 05:46 PM
ok so screw into the metal bars? Is there wood between the bars? My amp is a little off from the bars when it sits horizontal but vertical it fits nice and snug between but the mounting holes are between the bars, so I was wondering what is between them. I thought of velcro, but if the amp fell off when the seat was up it may damage my amp. I want it secure.
Old Feb 27, 2003 | 06:20 PM
digdat's Avatar
I'm getting mine mounted to my back seat as we speak. I have a 1200w Power Acoustik amp, which is pretty damn long .. so Its gotta be mounted to both. Will prevent me from dropping one side of the rear seat at a time .. but I dont mind. Its convenient and out of the way from the rest of the trunk. Amp should bolt right onto the back of it.
I like the idea bout the velcro ... would need a good sized sheet thou
Old Feb 27, 2003 | 09:02 PM
Nero's Avatar
although it seemed like a good idea at the time it left a bunch of holes in the carpet on the back of my seat plus my amp is really big and would only fit vertical. i thought about doing it across both seats bit i like to roll with the small door down for more bass.
also anyone ever look at the plastic part behind the arm rest? i was thinking about either cutting it out all togther or cutting like a big logo...am i crazy? please let me know. again crusin_lancer if it were me i would do an amp rack mount my amp there with a cap and a distro block. its your car just my 2c.
Old Feb 27, 2003 | 10:43 PM
I want to get as much space out of my trunk as possible but still have my subs, so that ellimnates the amp rack. That is why I'm wanting to put it on my seat and it will fit perfect right on the big seat. But I'm still asking and my question has not been answered, what is between the bars on the back of the seat? Wood? or is it just metal? I have self tapping screws that are 1" long and am wondering if it is wood I can just screw them in if not I'll have to predrill. So my question is again is it wood or metal between that bars on the seats?
Old Feb 27, 2003 | 10:53 PM
Nero's Avatar
as far as i know its like a particle board if were thinking about the same spot. but why wouldent u want to just screw into the metal bars?
Old Feb 27, 2003 | 10:55 PM
because the amp is off just a tad that two of the holes miss the bars about an inch or so... so if I stick it in vertical then all four holes are between the bars and not kinda lopsided
DangerousDan
04-06 Lancer Ralliart How To Requests / Questions / Tips
54
Mar 13, 2017 01:27 AM
slebo3213
Apr 12, 2012 06:40 AM
woohooportland
For Sale - Cars For Sale
Mar 30, 2012 05:42 PM
Xearo
13
Apr 14, 2009 08:03 PM
blakevo8
Oct 11, 2007 07:11 PM
