Grounding Points
Old Sep 20, 2005 | 08:44 PM
logikalliquid's Avatar
Grounding Points
Where are you guys grounding your amps?
I heard the rear shock(or are they struts, I forget) mounts are good points for grounding. I haven't tested this out yet, but I coulda sworn I've heard something contrary to this a few times before. I have the grounds in the corners of the trunk with self-tapping screws. I guess I should break out the ol' DMM and test for myself where the lowest resistance point(s) in our trunks is(are) huh?
Old Sep 20, 2005 | 09:03 PM
jtralliart's Avatar
The bracket connecting the split folding rear seats to the trunk floor makes an excellent grounding point. I showed very little resistance on these two bolts with my DMM, just make sure you sand the paint off EXTREMELY well!!
Old Sep 21, 2005 | 08:23 AM
SLVROZ_03's Avatar
I just tapped a screw into the passenger-side trunk area, and of course scraped all the paint off until it was shiney.
Old Sep 21, 2005 | 10:14 AM
pumpdog720's Avatar
Ya, the trunk area seems to be fine. The metal area near the back seat if you lift up the carpet.
Old Sep 21, 2005 | 03:05 PM
diamondstar03's Avatar
I also used the bolts that were oem for the 60/40 seat where they bolt to the chassis.
srtboostin22
Jan 6, 2009 06:35 PM
Evo9Kid
Aug 27, 2008 11:39 AM
EvoIXMR
Jul 30, 2006 07:53 PM
RalliArtEvoVIII
Apr 5, 2005 06:17 PM
favre95
11
Apr 15, 2003 08:03 PM
