can someone tell me if this is right?!?!
ok. i have 3 amps and a cap.
to install the cap i would run the power cable to the cap from the cap to the block and then to the amps?
i have two 900 watt 2 channel and one 300 watt four channel. i only want the 900 watts to be connected to the cap. the cap is a 1.5 farad.
my friend told me sence i only want two amps to the cap that i should put the block before the cap and run one wire to the amp and the other wire to the cap and from the cap to both amps.
That will work just fine. Try to ground all of the amps in the same location if you can. Oh and you would not catch on fire, it would simply explode. no worries Just dont ground out the positive and negative lead of your capacitor and you should not have any troubles. I always mount the capacitor and ground it before charging it.
thanks..well i got everything set up..but when i went to connect power wire to the battery. i forgot to get a 4 gauge fuse holder i'll take pictures tomorrow so some can tell me if i did it right.
if i could make a suggestion buy a i believe 200amp fuse breaker for your car instead of a 4guage fuse block you will not have to buy fuses just in case you blow the fuse. the circuit breaker you just go and reset it and back in business i have one on my car and i spent maybe 25.00 with tax.
TxFAkuma
Feb 4, 2016 05:40 PM
WTB[Northeast]: Passenger side HiD headlight cap & OEM driver's side A-Pillar
NYC4g63IX
Aug 18, 2015 11:27 AM
yellance
Dec 12, 2007 02:18 AM
