system pics
Old Apr 5, 2006 | 10:22 PM
kfos01's Avatar
Originally Posted by BillAce
This is the console where my AEM display is. I have no extra gauges as this will display everything you can imagine and has warning threshholds that flash led's in the cluster and the console.
I haven't heard of this. I might have been living under a rock. Can you give a few details on where I can look at this?
Old Apr 6, 2006 | 05:43 AM
BillAce's Avatar
It is made by a company called Gauge Tech, the guys name is Kevin. I took the controls and LED off the circuit board and made a new button control panel that takes the place of the IC spray button since it isn't needed. I then put LED's in visible locations for warnings.
I just cut a big hole behind the shifter and glassed it to allow a good viewing angle with no glare. The unit is mounted to the lower console where I made the recess that holds the display. It powers off of the cig lighter 12V since it is gone.
Old Apr 6, 2006 | 05:55 AM
BillAce's Avatar
Originally Posted by DrifterStudios
Bill, I have a lot of interest in how you time tuned the tweets to get ariveal to match the mids... are you using a signal processor to retard the release of the tweets? Also what slope are the tweets falling off at and what freq. I am looking to mount mine in custom door pods but thats a very tight area for 6.5 and 1" soft domes, plus I know the sound path isn't clear... damn cars, should only have one seat in the center...
I have an Audio Control IASYS analyzer. It provides full frequency time, phase response and amplitude plotting. My speakers are the reason I can pull off what I've got with analog (no delay) processing. The tweeters have a large chambered billet rear housing. The xover point is 910Hz @ 24db slope. This is not something you should do with a speaker meant to xover @ 4.5Hz.
My 6.5" uses a silk cone with a huge motor structure. It only needs to play up to 750Hz and it is fast. Since the mid mount wasn't going to change, I measured the time response and mounted the tweeters at the correct height ans axis to have the same arrival times. This was done L tweeter/Mid and R tweeter/Mid as the L/R difference is still around 10%. Setting phase properly eliminates the side bias.
andrewRA
09+ Ralliart Show and Shine
15
Nov 1, 2010 08:46 PM
Walkingchaos
Nov 18, 2005 04:35 PM
lucky04
33
Jun 13, 2005 01:53 PM
forum04pl
Apr 9, 2005 03:58 PM
bpclements
Dec 19, 2003 07:33 AM
