X-Mas list
Old Nov 3, 2006 | 02:44 PM
bene's Avatar
they make ported cuz they make both for every type of sub. kicker makes a special factory ported box that comes with it and sounds great with smaller amps ones that cant make it hit hard, but sense the air flow isnt restricted/sealed it makes a pop/fart at high watts which doesnt sound good at all
i started with a ported box and learned that the sub wasnt made for one
and i dont mean just hook one coil up u just hook up each one individually + - terminal to + - coil straight hook up its 2 ohms
but yeah if u dont plan on getting a bigger amp then get the 4 ohm
4 guage wire runs fine, i put 0 guage without having to fabricate or anything
the sub will be fine until 1000+ watts which u wont be passing
Old Nov 3, 2006 | 06:04 PM
Never Satisfied's Avatar
Bene is right about the 4-guage, most people haven't had to modify anything to run it. I took a slightly more complicated location and made it work.
Truth be told, all ported boxes will give you port noise. Depending on the size and shape of the port, the noise will be more or less noticable at the same power. The more power applied, the more noise you will hear. Sealed boxes, on the other hand, are alot more versitile and lend themselves better to most applications.
That Kenwood amp will probably never give you a true 900 watts RMS. You should expect it to be more like 700-800, depending on the conditions at a given point.
Best of luck to you with your project, and hopefully you will have an enjoyable system when you get done.
Old Nov 4, 2006 | 04:30 PM
aquaman's Avatar
So can you guys find me a good box and wiring kit... I'm having trouble finding them. I mean I can find some but their all less then a cubic foot (box) and the wiring I'm 100% sure what I need.
The computer has been runing real slow and it takes like 20 minutes just to get to the internet, so it would be awsome if one of you guys can get me those two things.
thanks
Old Nov 4, 2006 | 06:41 PM
bene's Avatar
you dont need much for wiring just a simple http://sonicelectronix.com/item_7575.html
and ill look for a box for u later
Old Nov 5, 2006 | 08:44 AM
aquaman's Avatar
thanks bene.
kidneythief13
May 24, 2008 02:57 PM
ImJoey
Jun 27, 2007 04:05 PM
Chewie4299
Feb 4, 2006 06:58 PM
SLVROZ_03
11
Jan 9, 2006 01:22 PM
Scottp
Jul 9, 2002 03:02 AM
