having problems with wiring diagram
Hey guys bought an alarm and am getting ready to install it. Now the only question i have is which of these door lock wiring diagrams do i use to connect to the cars system. I'm work as an electrician and this is making no sence to me. The rest of the alarm does but not this. And I know that the Power Lock purple - driver kick, door harness Power Unlock lt. green - driver kick, door harness. So help me guys fulfill me with ur wisdom
its from an alarm that i bought and this is the locking wiring diagram and i don't understand it. i know we only have the 2 wires to connect to but this alarm gives me to options positive touch off or negative touch off (as the diagram calls it) and i don't know which one to do
its one of the two diagrams on the top right just don't know if i should connect the other two wires to a positive source or ground then out. my electrical background makes me think ground them but then again my electrical background also makes me think don't "just try it" on things
Here is the wiring diagram for your vehicle. The locks are negative trigger, meaning a ground pulse will activate the lock/unlock. Wire your alarm for the negative type door lock system and you'll be fine.
12volts white + ignition harness
Starter black/yellow + ignition harness
Second Starter N/A
Ignition black/white + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory blue/black + ignition harness
Second Accessory blue/white + ignition harness
Notes: Not required for remote start.
Keysense blue ignition harness
Notes: The wire rests at ground with the key out of the ignition cylinder, and goes to an open circuit when the key is inserted.
Lock Motor blue/red 5wi driver kick, door harness
Unlock Motor white 5wi driver kick, door harness
Parking Lights+ grn/yel (L), grn/wht (R) + wht plug bottom of fuse box
Parking Lights- N/A
Hazards white - hazard switch
Turn Signal(L) lt. green or white/blue + driver kick, harness to rear
Turn Signal(R) yellow + driver kick, harness to rear
Reverse Light brown + driver kick, harness to rear
Door Trigger white - wht plug bottom of fuse box
Dome Supervision use door trigger
Trunk/Hatch Pin green/orange - light in trunk
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm gray - driver kick, door harness
Disarm No Unlock N/A
Tachometer black/yellow or black/green ac either ignition coil
Wait to start N/A
Brake Wire green + brake pedal switch
Parking Brake blue/red - parking brake switch
Horn Trigger yellow - steering column
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Parking Lights- N/A
Hood Pin N/A
Wait to start N/A
awesome thanks guys got it all wired up the only tricky one was door trigger cause there are two whites coming out of that plug but i guess i got the right one cause it works
ApexSilver06MR
14
Dec 21, 2009 08:44 AM
benji
34
Jun 4, 2009 07:31 PM
Evolution8RS
Mar 20, 2009 09:36 AM
WRC4ever
Jan 29, 2004 08:31 PM
