Rear window ledge rattle...how to fix?
Old Jun 6, 2003 | 05:01 PM
Sailorgoon's Avatar
Okay here's the deal.
I've got 2 old 12" Pioneer 450W IMPPs in my box in the trunk. I'm running them off a 500w amp turned up a little less than halfway. The bass sounds good and clean, except for the rattling the car does.
My front doors rattle, but that's not my prime concern. The rear window ledge rattles and it moves up and down. You can actually see the ledge rise and fall. I know some others had trouble with this long ago, but my attempts to find the info via searching has done no good.
How did you remedy this problem? Is there a way to secure the deck so it doesn't bounce around like a superball?
Any input is appricated.
Old Jun 8, 2003 | 11:19 PM
Zeeshan's Avatar
i got the same problem, help please
Old Jun 8, 2003 | 11:37 PM
Iamkar33m's Avatar
Same problem here... dynamat don't help
Old Jun 9, 2003 | 09:06 AM
Higgity Hank's Avatar
3/8" peice of plywood, cut and contoured to the rear deck, layed in with a layer of Dynamat Original, and some heavy adhesieves, fimrly attached with self tapping screws did the trick for me.
But I'm a freak...
Old Jun 9, 2003 | 09:31 PM
DjDoubt's Avatar
HELP Same Prob
I have the same prob, I have a roll of DynoMat But how do u get the Damn Deck off? I took off the child safty seat holder and all but damn thing is on tighter than anything
Old Jul 17, 2003 | 08:44 PM
IILANCERII02's Avatar
ya have this same problem, tried putting an ol' towel down for a temp fix, didnt help to much.
Old Jul 18, 2003 | 09:17 AM
dreday's Avatar
hey Higgity Hank... could you take a pick of what you did so i can understand alil better... i got the same problem and i'm kindof out there in crazy peoples land
Old Aug 4, 2003 | 12:20 PM
purecoda's Avatar
even easier fix...
get some foam shoe inserts, the cheap ones from walmart, and cut it into 3x3 inch sqaures. from under the deck, through the trunk, place the squares into the holes (pics to come).
my rattle is gone, and it only took 5 minutes.
Old Aug 4, 2003 | 01:12 PM
purecoda's Avatar
https://www.evolutionm.net/forums/sh...803#post388803
Old Aug 4, 2003 | 09:27 PM
Dr Crash's Avatar
the sugestion by higgity hank is a nice way to solve this. another is to use nearly the same type of foam that is used in surfboards, works great.
coda: nice work on that dynamat buddy! looks really clean
Old Aug 5, 2003 | 10:33 AM
purecoda's Avatar
thanks doc
i'm trying to figure out now what's the best way to make a nice clean install on the rear dash, without really blocking or jamming any screw holes.
Blue_05EVO
Midwest Region
12
Dec 8, 2011 04:02 PM
AcePitcher11
12
Jun 29, 2011 05:07 PM
Evo8
May 19, 2011 06:15 AM
Gamma286
Sep 24, 2007 03:50 PM
