Speakers "POP" during power on...
Old May 10, 2007 | 12:51 PM
sykou's Avatar
okay heres an update. I soldered the resistor into the REM line and my amps would turn on but wouldn't play anything. It does this also when the voltage on the REM wire is too low so i tried removing it and then it worked fine... Is the resistance too high or something?
Old May 12, 2007 | 08:16 AM
Never Satisfied's Avatar
Yeah, go with a lower rated resistor. What size did you have in it?
Old May 14, 2007 | 03:45 AM
sykou's Avatar
1000 ohm... what should i go with? oh and by rating your referring to the resistance right?
Old May 14, 2007 | 09:44 AM
Try a 500... and if that doesn't work, just go down a bit from there until you find the one that does it. The ultimate goal is to have it not pop when you turn on everything, but to still have it at least turn on.
Unfortunately, every amp is different, so I can't tell you an exact number. ALot of times it is a trial and error thing.
skikarl
Lancer Troubleshooting
Nov 3, 2014 11:39 AM
5LEEPERISAH23I
18
Oct 1, 2010 11:14 AM
Tadz0rz
Feb 9, 2009 04:55 AM
PurEvo
Oct 4, 2006 05:31 PM
ralliart 04 21
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jun 24, 2006 07:41 AM
