Amping speakers
Old Aug 23, 2007 | 10:42 AM
diamondstar03's Avatar
Originally Posted by CUSTEL
No, it's not working twice as hard, how would it work twice as hard, that doesn't make any sense. There is no problem with under powering a speaker. That's like saying you cant hook up aftermarket speakers to a factory headunit, sure you can. They won't receive proper power but they will function fine. Bottom line is don't talk speak upon a matter you know nothing about.
Well you are both somewhat correct however the problem with that he is experiencing is that he is not getting enough volume out of the speakers. If you put more power to the speakers then you will get increased volume with less distortion so you will be able to get alot more sound out of the speakers which is what is he wants. It is very true that it is better to over power a speaker (within reason) rather than under power the speaker. The signal travels in waves and if you try to get more out of the source than what it is physically capable of then the waves begin to deform (clip) this is what blows speakers. Sure you can power aftermarket speakers with less power and they will work however you will not get peak performance from them which some people are fine with.
in short ....get yourself a 50-65 watt X 4 amplifier and and run new speaker wire to the speaker locations and it will be a dramatic difference.
Old Aug 24, 2007 | 12:22 AM
DontRevMe's Avatar
No that is pure ignorance speaking, underpoering does not create distortion rather it does not show the true potential of the speaker. Possibly being to quite for the listener in which in turn they will up the gains and end up with ruined equipment. Don't talk out of your *** if you don't know the truth.
You need to relax.
back on topic, as far as I'm concerned, the more headroom the better
kericr
14
Dec 15, 2023 12:28 PM
bardia1985
Jul 4, 2012 09:05 PM
grizly3610
78
May 17, 2010 03:12 PM
K1tt3n5
13
Dec 19, 2009 03:50 PM
lancer2show
16
Apr 10, 2008 12:32 PM
