Subwoofer Advice
Old Jan 7, 2008 | 11:12 PM
shinbumee's Avatar
Subwoofer Advice
hello, i posted about the weird sound before.
I'm also trying to get a new subwoofer (preferably with the enclosure and amp altogether). is Visionik Okay?
I currently have 4-channel amp in my trunk.
When installing, should I make another separate power cable or strip off little part of power cable from the 4 channel amp and connect it to the amp?
Thanks.
Old Jan 7, 2008 | 11:24 PM
spedfrek's Avatar
i have a memphis mojo 12 with 2000 watts o juice. hits like a truck.
Old Jan 7, 2008 | 11:28 PM
chetman7's Avatar
^^ didn't really answer his questions
Old Jan 8, 2008 | 01:42 AM
J Money's Avatar
i've never heard good or bad of visonik so i'm not really sure...wuts ur budget for everything? cuz theres prly a better bang for ur buck out there
and when u split the power ur gunna wanna buy a distribution block and go through that..run ur power from battery to that..then to the seperate amps
Old Jan 8, 2008 | 02:01 AM
a2stepawd's Avatar
I wouldn't get visionik...they are a cheap kind of brand..
What gauge wiring are you running right now to the 4 channel amp?
I would suggest 8-10 gauge for the 4 channel and 4 gauge for the subwoofer amp.
If you can't run both, I suggest running a minimum of 4 gauge and getting a distributor block.
That would then divide the wiring into 2 or more outputs depending on how many outputs the distributor has.
So from there, one wire going to the 4channel and then the other to the sub amp
One sub I never regretted getting was a 12in sony sub... I had got 2 with the amp and boy did they hit hard. I was expecting a little less, but they did the job
You can now find them online for around $60 search around and you will find some.
Old Jan 8, 2008 | 11:49 AM
J Money's Avatar
like i said..it all depends on wut u want to spend on a sub(s) an enclosure and the amplifier...then u hafta put into play price of wire and rca's..and if u know how to do it urself u'd save some money
Old Jan 8, 2008 | 12:12 PM
shinbumee's Avatar
hmm... since i don't know many facts about wires and stuff... what would be the easiest and simplest way to get a sub/amp, a bit of quality with little cost of money?
Old Jan 8, 2008 | 02:12 PM
SLVROZ_03's Avatar
^Do the install yourself and buy used. Assuming you used 4-ga on the 4-ch, split the power using a distribution block. Run the extra RCAs where you did the others. Ground in a different location than the other. Upgrade the in-line fuse from the battery for use with the two you'll now use. make sure your battery is up to the task.
Old Jan 8, 2008 | 04:47 PM
J Money's Avatar
if u dont know how to wire up a system..or dont know someone who does..u might wanna get it done..altough its not really hard and there are walkthroughs on this website so its rly up to you..
and i dont know wut you consider a "little cost of money" so it's hard to say whats the best route for you
when buying a system its a good idea to have a general number of how much u wanna spend
Old Jan 8, 2008 | 09:53 PM
shinbumee's Avatar
okay~
Thanks,,
Old Jan 13, 2008 | 08:34 PM
shinbumee's Avatar
Hey guys, I'm sorry to ask you guys one more time about how to put the distributor block.
To upgrade with better fuse, do i just change with higher amp fuse?
For the block, Do i have to buy the one with 1 in and 2 out?
Then... Do i have to cut the power wires short and put 1 in 4 ch amp, and 1 in sub amp?
RCA cables, i know and... how about the remote wires?
Old Jan 13, 2008 | 08:50 PM
housedj's Avatar
u will have better success asking on the car audio forums vs here. it is difficult for us to explain & offer options to you as we don't know what skills u have in regards to car audio installation. do urself a favor & start out by going to www.crutchfield.com & they have info on how to wire up equipment specific to ur car & then we won't have to hear you whining about u frying ur electrical system in ur car a month from now. if u want a budget setup get this:
the Blaupunkt thb-200a retails for around $200 & is a powered sub.
if cost is no option then either build a box or have a box built & use the sub & amp of ur choice. here would be my choice:
http://www.imagedynamicsusa.com/tech...e=sub&id=idmax
& this new amp from JL Audio:
HD600/1 - 600 Watt Monoblock
Type: Class D, Full-Range Amplifier
Continuous Power: 600W x 1 @ 1.5 - 4 ohms
(11.0V-14.5V supply with <0.08% THD+N)
Dimensions: 10.75 x 7.87 x 1.93 in.
(273 x 200 x 49 mm)
Available: 2nd Quarter, 2008
http://mobile.jlaudio.com/jlaudio_pages.php?page_id=239
Old Jan 13, 2008 | 11:59 PM
J Money's Avatar
IF money is no issue i would just go out and buy a memphis mojo (all you need is one) and a memphis m-class amp..and you will be the loudest car on the block
but that is by no means cheap...i think just one mojo sub retails at like..600..or sumthin
Old Jan 15, 2008 | 08:57 AM
Slekd's Avatar
Thanks.
are you talking about the OEM subwoofer on the Lancer 2008 ?
Old Jan 15, 2008 | 07:32 PM
shinbumee's Avatar
no no 2003
