Headunits .. what ya rolling with?
Old Aug 10, 2003 | 12:30 PM
  #31
kidnice's Avatar
One more question, I swapped my HU and smk, and the HU is in the lower din. Do you guys think there is enough clearance for one of these HU's with lcds?
Old Aug 10, 2003 | 12:34 PM
  #32
GTVEVO's Avatar
I don't think so if you have it in the bottom. If it fit it would probably be hard to see because you would need to tilt the screen up then your dash would be in the way. You could take it to a shop and get a second opinion but they would probaby say the same thing.
Old Aug 10, 2003 | 12:49 PM
  #33
kidnice's Avatar
Thanks, I didnt think of that. Totally forgot that lcds are hard to look at if the position is not right. I guess I'll have to move on with my kenwood mp922 for now. Regretful I am for not dishing out a little extra for a lcd hu.. oh well
Old Aug 10, 2003 | 01:00 PM
  #34
GTVEVO's Avatar
Another sugestion is that you could always go with a external unit in the visor or somthing that way you could have the best of both worlds, just an Idea though.
Old Aug 11, 2003 | 07:20 PM
  #35
GTVEVO's Avatar
Headunit with the LCD Screen closed. The Clarion has a normal LCD on the top of the actual LCD screen that retracts back in its close position.
Old Aug 13, 2003 | 06:31 AM
  #36
Jrod@Buschur's Avatar
I've never had any problems with my deck skipping or anything. Most in car dvd palyers will NOT play burned movies mostly CHEAP dvd players you can put in your car will. like the ones that are 1 DIN size but not decks it's something they put in the DVD that makes it play or not quality stuff usually won't cheap stuff does. screw cheap stuff put a nice headunit in there and a X-BOX. The X-BOX plays burned DVD's and you can play games and all that good stuff. Good Luck
Old Aug 13, 2003 | 06:33 AM
  #37
GTVEVO's Avatar
very true , I wasn't even thinking of that. If you have inputs you might as well use them!
Old Aug 13, 2003 | 07:13 AM
  #38
This guy knows what i'm talkin about! I just read through my last post and I left a couple words out I see. Anyways you all know what i'm talkin about. Basically the last part was the most important.
Old Aug 13, 2003 | 08:13 PM
  #39
Dr Crash's Avatar
gtvevo: i didn't think there was a difference between a + and - as far as labelling was concerned. i think they are the same thing.
Old Aug 14, 2003 | 05:17 AM
  #40
GTVEVO's Avatar
To my understanding the -R are the first gen DVD lasers the +R are the second Gen laser, Currently from the research that I have done only about 10% of DVD Players will play -R disks and about 80-90% of DVD Players are compatible with the +R burn style. If you look at the DVD Burners they have some that are +- and some that are just - or + compatible and you have to buy the - or + disks to run with them. Minus disks are cheaper and they have been around longer but plus will play on more machines and are more expensive, not by much though.
Old Aug 25, 2003 | 07:33 PM
  #41
lanceroz03's Avatar
i got the eclipse av8022
Old Aug 31, 2003 | 03:45 AM
  #42
jfh's Avatar
jfh
Alpine CDA-7995 (no internal amp) with JL Audio 500/5 Amp
Old Oct 4, 2003 | 07:53 PM
  #43
oz-e's Avatar
i'm an xplod guy lol
srcevo8
14
Jun 4, 2009 11:47 AM
gaga123
Feb 8, 2008 11:38 AM
Evo23IG
39
Oct 28, 2007 03:26 PM
pusha2009
Oct 17, 2005 01:01 PM
Hellraiser
120
May 19, 2005 02:13 PM
