PAC SWI-PS and Bluetooth
I am confused. What do you mean by it activating? The factory bluetooth will only work with your factory radio. You shouldn't have that plugged in if you are using a pac unit.
However, when connecting the PAC SWI-PS, the steering wheel "seek up" button automatically re-routes to activate the factory bluetooth. This makes it impossible to program "seek" buttons using the SWI-PS unit.
Next weekend, I will disconnect the factory bluetooth module and see if the issue is resolved.
The factory bluetooth module is separate from the factory head unit. It functions regardless of the head unit that you install. When I removed the factory head unit, I didn't touch the factory bluetooth module or switches. I have never used them and figured that there was no harm in leaving them in place.
Without the factory head unit no signals from the steering wheel go to the bluetooth module. Which is why I am confused by what you are saying. I also am confused because without the factory head unit you should hear and see nothing from the bluetooth module because it is not wired directly to your steering wheel.
The whole reason the bluetooth controls work with the pac unit is because they are sent over the same (single) wire as the audio controls. If they were somehow tied directly to your bluetooth module you would have two control signal wires. This will not work with a pac system and you wouldn't be able to use the bluetooth buttons.
Sooooo since we know they are on the same signal wire, which you are unplugging from the factory radio to splice into. There is no connection ever being made to the bluetooth module
Unless they changed something from my 2008 Lancer I disagree.. I know the module is separate, it is located above your glove box. What I am saying is that the factory head unit is needed to use the bluetooth module. Your head unit receives audio from the bluetooth module and outputs it to the front passenger door speaker. Your steering wheel control wires go to the back of the factory head unit. Wires then go from the head unit to the bluetooth module to tell it what to do. This is how you see phone calls, etc on your factory radio display. Essentially the brains of everything are the factory head unit. The bluetooth module is there to make a bluetooth connection to your cell phone.
The bluetooth unit that I have operates totally separate from the head unit. It only uses the head unit for two functions: 1) to provide sound (any head unit will do as long as it's plugged into the factory wire harness) and 2) to display the caller (obviously, the factory head unit is needed for this function).
The head unit does not provide an signals to the bluetooth module. This is why there are no buttons on the head unit that are used to control the bluetooth module.
Although there is only one control wire at the connector end of the harness, this wire splits downstream. It feeds into the head unit AND the bluetooth module. The bluetooth module only reacts to certain signals. The head unit only reacts to certain signals. Thus, they can be connected to the same wire. This is also why you have to program the SWI-PS unit. Programing the unit tells it what signal to send downstream.
Hope this clears up the confusion!
Now on to the original question at hand... how are you saying this bluetooth module is being activated without the factory head unit because as I said before this is the operation of the 2008 Lancer, and I don't think they changed anything in the newer models, but am positive about 08. I am in fact the original poster of this topic so I think I should know a little.
OK, I’ll post one more response to this thread before moving on, LOL!
The factory head unit uses the same wire harness as the aftermarket head unit. That’s how the audio signal from the bluetooth module is sent to whatever head unit is connected.
This statement alone makes it evident that you do not fully understand the process. The head unit just manipulates the audio signal. It does not tell the bluetooth module to turn up/down the volume, LOL.
The PAC unit provides resistance when the buttons are pressed. Your car does not have to be running while programming the unit. You just have to turn your ignition to the "accessory" or "on" position so that the unit receives power. I'm not sure what you mean when you say that your car has to be running to make sure that you have good levels. That's a new one to me.
Like I said before, either you have a different type of factory bluetooth than andrewp and I, or you are just guessing in regards to the manner in which your unit functions. The fact that I have an aftermarket head unit and can still use my factory bluetooth proves this. Also, just because you are the original poster of this thread doesn’t mean that you are an authority on the subject!
No other head unit but the factory one will do this. The wire harness has output wires for each speaker, power, ground, illumination, etc. The bluetooth module does not just send audio over a wire and magically output to the right speaker. The audio needs to go through an amplification process done by the FACTORY HEAD UNIT.
You do realize the signal going across this wire is a voltage/current level correct? Certain buttons will change the voltage/current to a certain level. This is why you program the pac unit to send certain button presses at certain level changes from the signal line. This is also why you have to have the car running while programming to make sure you have good levels.
Okay so Iggman and I are still in the same boat....my seek up still activates the bluetooth. I dont know why, i called PAC support and even they dont know...
So anyone disputing this, stop...the problem exists...now dont post regardless if ur some senior blah blah blah tech unless you have a solution.
I did the aftermarket install myself, did it all to spec and everything works except the actual bluetooth...
Anyways...lets find a solution
And looking at Lancerion's pic I just noticed the blue wire that he clipped right beside the 22)
Is that supposed to be clipped?
And I also discovered i come into my car and sometimes my head unit is muted....
I actually press the seek up to unmute the unit...and on the wire harness from the unit i didnt connect the mute button because it was an issue.
Iggman you ever have the same problem?
OK, I figured out the solution to my problem so I thought that I'd post another response in case this helps someone. As I suspected, disconnecting the harness to the factory bluetooth module has completely eliminated any issues that I had been experiencing. I can now program all steering wheel buttons and everything is working great!!!
If I had to guess (yes this is just a guess) as to why some of us are experiencing issues and others are not. Perhaps this issue only occurs with certain revisions of the PAC unit. As noted in the table listed at the link below, revisions 1.6.7 and 1.6.8 added some additional programming options (FYI my unit is revision 1.6.8, the most recent revision).
http://pac-audio.com/swixprogramming...ehicles&ID=243
I hope this helps someone
P.S. andrewp, PM me if you have any specific questions. I probably won't be monitoring this thread. Be careful though, although I am not an engineering student, I am an engineer!
we need a solution:
i am using a mito-02 and a swi-jack ... I too get the "seek up" issue. "hands free" operates just fine but again it is activated by "seek up" now.
I have removed the Bluetooth module temporarily, which as noted by other members allows the stereo control buttons to be properly programed.
However this is unacceptable, as the hands free system still works great "when plugged in" the buttons are just messed up. i wish to keep the factory hands-free system and the hands free buttons on the steering wheel. it would seem this is a simple issue!
help please!
help please!
kilroywzhere
Sep 16, 2015 08:50 PM
