question about amps
Old Feb 19, 2010 | 10:04 AM
smokem22's Avatar
question about amps
So this may be a little technical but figured there are some pretty knowledgeable people on here. With the stock RF amp if you stop using it to power the 10"sub would that allow what little power that was used by the sub to be allocated to the other speakers or am I just hopeful wishing here lol.
Old Feb 19, 2010 | 10:08 AM
evolvd276's Avatar
dont quote me o ths but im pretty sure thats correct if you disconnect the sub the power will be then evenly distributed to the other speakers.
Old Feb 19, 2010 | 11:47 AM
yitzac1990's Avatar
lol no it wont. its a (however many)-channel amp. the power on the sub channel is ONLY for the sub
Old Feb 24, 2010 | 06:22 AM
smokem22's Avatar
alright well if I add an amp for an aftermarket sub cut the sub wires to the stock amp use the scosche loc80 with those wires, switch out the amp for a 4 channel will I lose the bluetooth and sub volume control? I know I will lose the equalizer. just to double check the LOC hooks up to the speakers your using right not the line in for the stock amp? Thanks
Old Feb 24, 2010 | 07:45 AM
yitzac1990's Avatar
if you are going to do all that, get an aftermarket HU anyways. you can get Pioneers for 200 bucks or less with BUILT IN bluetooth, meaning no extra module or anything needed. make sure it has 6 channel RCAs though (front, rear, and sub)
Old Mar 2, 2010 | 09:47 AM
smokem22's Avatar
if I get a diffrent head unit will i beable to use the volume controls on the steering wheel?
Old Mar 2, 2010 | 11:25 AM
yitzac1990's Avatar
you will have to get an interface module from PAC....i forget which model, but it depends on the vehicle and if the radio has a wired remote input in the back.
Kartyman550
Aug 29, 2013 08:11 AM
DJAfterShok
37
Nov 19, 2010 08:19 AM
Rod Munch
12
Jan 11, 2008 10:51 AM
Smoktout
Apr 24, 2003 03:27 AM
