6.5 speakers
Old May 8, 2004 | 10:38 AM
scooter16's Avatar
6.5 speakers
When I was driving one day all my factory speakers went out. I posted that and everybody told me that my speakers were blown. So I went out and got 4 6.5 sony explodes and installed them and they still wont come on. Does anybody have a clue whats wrong. The CD player turns on and works fine and the subs turn on and work fine but the rear panel speakers and the door speakers wont turn on even though I replaced them. Somebody please help.
Old May 8, 2004 | 11:08 AM
sr20det91's Avatar
Are the speakers runninig off an amp. If so you may have blown a fuse in the amp or lost the signal going into the amp. If not, its probably something in the head unit. It would be really odd for all your speakers to blow at the same time, and usually when a speaker blows it just sounds like crap rather than going completly out. I would start by checking all connections and fuses.
Old May 8, 2004 | 01:52 PM
Lance Dogg's Avatar
i think your main problem is the fact that you bought sony xplodes. lol, just playin. i'd agree with mr. nissan motor (sr20). probably somethin with the head unit. is it a factory head unit?
Old May 8, 2004 | 07:18 PM
scooter16's Avatar
It is running off of the CD player. I installed a new pioneer 200 watt amp. I just dont see why they dont work. I'm going to do the things yall told me and i'll get back with yall. But keep gliving me suggestions please. I'll try everything.
Old May 8, 2004 | 07:32 PM
Lance Dogg's Avatar
you said a 200 watt amp... is that amp powering the speakers? and, how did you install the amp using the factory deck? did you use the line-out converter behind the radio or by the rear speakers?
Old May 8, 2004 | 11:56 PM
scooter16's Avatar
no the CD player is 200 watts and the speakers are running from the cd player.
Old May 9, 2004 | 09:51 AM
Lance Dogg's Avatar
so... it's not a 200 watt amp, it's a 50 x 4 pioneer head unit. now, i gotcha. let's get everything straight...
did the speakers stop working the moment you hooked up the pioneer deck? if so, did you wire everything up properly? where did you buy the head unit and what wiring harnesses did you purchase for it?
Old May 9, 2004 | 11:18 AM
scooter16's Avatar
When I installed it everything was working fine for about 2 weeks. Then one day when I was driving they just cut of but the subs kept playing.
Old May 9, 2004 | 02:25 PM
Lance Dogg's Avatar
did you pull out the radio and check all of the connections? it might just be a radio with a fried internal amp. the subs should still play no matter what, they don't use the same amp that's inside the head unit. the head unit has a 50x4 that goes to the speakers. the amp that powers the subs just uses the head unit's RCA signal.
Old May 9, 2004 | 02:56 PM
scooter16's Avatar
How will I be able to tell if it is the internal amp and if it is where can I get another one
Old May 9, 2004 | 03:04 PM
Lance Dogg's Avatar
you can't just replace an internal amp in a head unit. you have to get a new head unit. if the head unit is under any kind of warranty or service plan, get it checked out. but... first, did you pull out the head unit and check all wiring connections??? try takin it to a local circuit city, they can probably look at it for you and maybe diagnose your problem.
Old May 11, 2004 | 03:10 PM
scooter16's Avatar
yeh I did and i'm going to take it to circuit city
Old May 11, 2004 | 03:55 PM
Lance Dogg's Avatar
good luck... let us know how it works out!
Old May 20, 2004 | 04:10 PM
xenonlancer03's Avatar
check your cars fuse box a friend of mine had xplods he always blew a fuse in the cars fuse box. who knows it might help u
good luck
OZKID
Apr 2, 2013 06:46 PM
PurgeIt
Feb 24, 2009 08:26 AM
scooter16
12
May 8, 2004 09:55 AM
GCbanana
Sep 18, 2003 08:35 AM
abc123
11
Sep 14, 2002 02:15 AM
