How much better?
Old Jun 7, 2004 | 09:46 AM
blaze_125's Avatar
How much better?
Once again, I'm starting to shop around for my new trunk setup.
I currently have a Jensen XS1212 (500 watts peak), and will probably upgrade to a Kicker Solo-Baric L5 8"
http://www.etronics.com/product.asp?...ore=&catid=374
Will I notice a huge difference in quality?
Old Jun 7, 2004 | 01:14 PM
Spiderman's Avatar
yes
Old Jun 7, 2004 | 03:05 PM
blaze_125's Avatar
My XS1212 is already mounted in the best box possible(to the manufacturer's specs), do you think this Kicker(again in the best box possible) will be louder. The db specs were are higher on the Jensen sub, but I think kicker is way better quality, which is why I'm asking.
BTW, this is the forecasted setup, but with only 1 sub...
Old Jun 8, 2004 | 09:30 PM
SK Lancer's Avatar
rear-firing, (slot) ported will go louder.
Old Jun 9, 2004 | 11:27 AM
blaze_125's Avatar
Yeah but I'm more into quality right now. Ported will shell out more SPL, but if I go sealed and have the cone inside the cabin, I should be getting back those lost db.
Old Jun 9, 2004 | 11:35 AM
SK Lancer's Avatar
No, tune the port to a nice flat frequency response and it will sound just as good...
The only time you want the subs facing into the cabin is when you have the trunk TOTALLY sealed off from the front (that includes the top deck, seats, etc...)
So you lose your 60/40 split and you have to do a lot of work on the rear deck.
Rear firing, ported.
Rear firing sealed will work too...(and round speakers sound better than square or oval speakers) (this is same for 6x9's and square subs! )
Old Jun 9, 2004 | 12:15 PM
blaze_125's Avatar
I'm not sure I understand you correctly here. My sub wouldn't be freeair. There would still be abox behind the seat. As for the port, I don't think I have the correct knowledge to tune such a thing.
I heard before about the square sub's SQ, but I figured it would sound much better than my Jensen. Jensen subs are still pretty low on the quality chart I think. Are you suggesting I should keep my Jensen instead of going Kicker 8"?
The main reason for my redesing is weight issue. My current setup weights between 70 and 100 pounds. I would like to make this as light as possible without doing fiberglass. Any suggestions?
Would I be better with this
steveyrich
11
May 20, 2016 07:21 PM
TopLevelPerformance
Nov 7, 2011 07:33 AM
ChadB
For Sale - Miscellaneous Automotive
Aug 8, 2008 04:16 PM
pao
Jul 1, 2008 07:00 PM
