Speakers: Is anything better than stock?
Old Aug 19, 2004 | 12:36 AM
dizzigital's Avatar
Originally Posted by arm07
Its weird, from the start I knew that new speakers didnt really do much in terms of adding bass. But then I went on sound domain and started reading some reviews and they all made it out like adding in new speakers was like adding in 5 inch subs..
that's exactly what you're doing... putting in 5 or 6" subs with some separate highs... just make sure there's an amp behind em, otherwise you won't hear its full sounding, peak potential.
Old Aug 19, 2004 | 12:42 AM
arm07's Avatar
So will an amp add more thump to my car?
I was planning to get a sub an amp at the same time but I might get the amp and then later on the sub.
Old Aug 19, 2004 | 12:48 AM
dizzigital's Avatar
yeah.. it'll increase some bass with the mid's and high's, of course.. you gotta get a box with a sub or two if you want thick bass though.
Old Aug 19, 2004 | 12:52 AM
Sentinal's Avatar
putting an amp to the speakers will increase overall output it will increase bass but will also increase mid and high so your bass gain over other gain wont be noticeable It will allow you to play louder and still maintain good sound though and if/when you add subs I would highly recomend an amp to the rest of the speakers to ballance them out. JL all the way baby
Old Aug 19, 2004 | 01:03 AM
dizzigital's Avatar
yeah, this guys got it right on the button as far as side speakers are concerned. you'll be able to get the music a lot louder while still keeping your SQ (sound quality). see, there's only so much a speaker can do without some sort of enclosure (box). so if i'm correct, judging by your word "thump", i think you want some sort of speaker inside a box in your trunk. the door panels aren't gonna cut it and give you the "thump" you want --> only to some extent, but you can't shove a 12" woofer into your door, of course.
Old Aug 19, 2004 | 04:24 AM
Sentinal's Avatar
Just something else to think about smaller subs are more efficient have a better sound range and usually are more crisp and accurate than larger subs of the same class. I personally prefer 10's to pretty much anything (I use 3 10" JL's). I haven't tried it but I hear that 4 8" subs works good too.
PurgeIt
Feb 24, 2009 08:26 AM
Tadz0rz
Feb 9, 2009 04:55 AM
Rod Munch
13
Jan 4, 2008 08:34 PM
bigd31388
Lancer How Tos / Installations
Dec 2, 2007 12:22 PM
Kolee
Feb 24, 2005 06:24 AM
