Proper wiring?
Old Aug 26, 2004 | 05:18 PM
blaze_125's Avatar
Proper wiring?
I've asked that question before, but never got a clear answer, so let me ask it again I'm running 2 amps. 1 for the sub, and 1 for the components. Which amp should be wired first. Should I bring the RCAs from the HU to the sub, or to the components first?
Old Aug 26, 2004 | 06:10 PM
ghostrider's Avatar
So you're using one set of RCAs and splicing them? Not sure how much distortion would come into play with wiring one amp first over the other, so I don't think it'd matter either way.
Old Aug 26, 2004 | 08:47 PM
blaze_125's Avatar
Of course not...
1 from the headunit to Sub's input
1 from the Sub's output to components' input
Old Aug 26, 2004 | 09:06 PM
ryancb's Avatar
run two sets if not do the comp amp first then sub but i wouldnt do 1 set that is a no no in my book esp when can get an rca for under $20
Old Aug 26, 2004 | 11:09 PM
skiidaho1978's Avatar
If you have a throughput on your sub amp which im guessing your talking about run it there first then to the other amp, if you have one on both do the front amp first, you need more signal there for cleaner sound and bass can be more distorted and not sound as bad, personally id get a deck with two or more sets of preamp outputs.
Old Aug 26, 2004 | 11:10 PM
Ohhh and if you are which I think you arent but DO NOT splice RCAs rca cables have a resistance level to transmit the signal just like a speaker has a resistance level in ohms. If that makes sence.. anyways if you splice them you WILL screw them up.
Old Aug 27, 2004 | 07:34 AM
blaze_125's Avatar
Don't worry, I'm not splicing my RCA
Just so we undertsand each other clearly... I've got both input and output on both my amps...
Old Aug 27, 2004 | 07:51 AM
sleek_concepts's Avatar
im assumin your head unit doesnt have two rca outputs?? that is the only way i would run two amps.
Old Sep 2, 2004 | 09:55 PM
EvoVIIIGuy's Avatar
one set of RCA's
Sub amp first then component amp!
the cross overs on amps are usualy set up to run this way
Old Sep 2, 2004 | 10:32 PM
ryancb's Avatar
negative other way around
Old Sep 2, 2004 | 10:53 PM
Sentinal's Avatar
First off if your running subs you should have a deck with no less than 3 preouts...
take 2 of the preouts to the amp that is going to run your speakers 1st preout for the front set 2nd preout for the back set
then take the 3rd preout and run that to the subs and you should be fine this way you will be able to tune your system and add or decrease power to front back side to side and have your subs on a totally separate preout..
This is by far the best setup due to adjustability and this is really the way that systems were designed to be wired. If you don't have a deck with 3 preouts you really should think about getting one if you want to run subs
Old Sep 3, 2004 | 10:57 AM
yea blaze im sure youve got it done by now but yes run the sub amp then the componant amp. If that makes sence if you have problems PM me I can help yea out.
Old Sep 3, 2004 | 06:19 PM
blaze_125's Avatar
thanks guys. I tried both actually. Having the sub's amp wired first kinda sound better, so I've got it that way for now.
Old Sep 8, 2004 | 12:02 AM
kewl man glad to hear it hope it sounds sweet for yea any other questions dont hesititate to ask or send a pm bro goodluck with your lancer
BalistiK_EvoIX
12
Jan 13, 2009 06:49 PM
virtex
Jun 18, 2005 08:33 PM
jsfour
Jan 6, 2004 09:43 PM
TG LanceR
18
Aug 17, 2003 07:01 PM
Murch
Jun 10, 2003 01:23 AM
