Noobish Question
Old Feb 9, 2006, 08:15 AM
Nitrous2K3's Avatar
Noobish Question
I looked around and wasn't able to find an answer, so I am now asking. Is it possible to use the RRM PB V2 and an Apexi SAFC-II or is it redundent to use the two?
Old Feb 9, 2006, 08:30 AM
blaze_125's Avatar
Redundent.
SAFC modifies fuel value with RPM value
Piggyback Ver.1 modifies fuel value with RPM/Vaccum
Old Feb 9, 2006, 09:46 AM
HobieKopek's Avatar
Redundant.
Having two piggybacks would probably cause problems as both would either compete to alter signals to and from the ECU or would stack and overcorrect each otehr.
Old Feb 9, 2006, 01:02 PM
Nitrous2K3's Avatar
Well then which is better the PB or the SAFCII
Old Feb 9, 2006, 01:09 PM
blaze_125's Avatar
Opinions are biased on that one. If the SAFC can also alter timing, then SAFC would be better. If it doesn't they're fairly equal except in price.
Old Feb 9, 2006, 04:22 PM
Blacksheepdj's Avatar
Install and be done - Piggy
Install and tune tune tune - SAFC
SAFC will give better gains, as it will be custom tuned to your car. But tuning ain't cheap.
If you want something to install and enjoy, call RRM.
Old Feb 9, 2006, 05:12 PM
Go2fast's Avatar
PB is a pain in the a%$ to tune!!! I'd go with the afc probably!!! Thats what im looking to do.
Old Feb 11, 2006, 08:46 AM
What makes you think SAFC is easier?
You can tune it simply (add fuel, subtract fuel), but you still need a wideband and a dyno for proper tuning. And some datalogging software would be a good idea too.
Old Feb 13, 2006, 06:14 AM
blaze_125's Avatar
Ain't any harder than any other a/f controller. I've never tuned a thing in my life, got on the Piggy bandwagon and find it a piece of cake.
Old Feb 13, 2006, 06:24 AM
Danno's Avatar
^ Me too. Now I just need to buy the software from RRM
Old Feb 13, 2006, 08:25 AM
HobieKopek's Avatar
In all fairness though, you'll really only NEED the WBO2 for tuning, so if you're not street tuning then the WBO2 service provided by any good shop with its dyno tuning services should suffice. If you plan on tuning yourself then you'll want your own WBO2.
Old Feb 13, 2006, 11:33 AM
blaze_125's Avatar
Agreed. If you want to tune your-self, you'll need a Wideband or stick to a conservative map.
Abcastillo
Jan 25, 2017 06:55 AM
nesty2
Nov 10, 2014 09:42 AM
EVOXMAINE
Northeast Region
Nov 16, 2011 07:42 AM
localtoys73
Southeast Region
Dec 2, 2010 11:28 AM
4G63 T
Jun 27, 2007 08:08 PM
Quick Reply: Noobish Question
