Who else is running 440cc injectors?
Old May 27, 2006 | 08:37 PM
Z_Lancer_Man's Avatar
Question Who else is running 440cc injectors?
Okay, so as you may or may not know, I'm currently trying to go stage 2. I have some 440cc injectors and the SplitSec Piggyback (RRM) with software for tuning (using a AEM UEGO and EGT gauge). The 12:1 FMU is still in the system with my Walbro 255 and my bored fuel rail. So needless to say, I'm running pig rich. I've tried to cut enough fuel out at idle to get my AFRs up from being buried at 10 (or lower, thats the lowest the gauge reds) but I'm either rich or the car dies.
Who else is running (successfully) 440cc injectors and what are the details of your fuel system? What are you using to tune?
I have to get this car running good by Thursday night and get it boosting 10 PSI!
I'm considering finding another method of tuning like the SAFCII or eManage.
Old May 30, 2006 | 09:30 AM
Sicktght311's Avatar
Get rid of the FMU, thats the problem. THe thing is designed to work on stock injectors to throw in more fuel than the injectors could control by themselves. So with the 440s you are puttin gin wayyy to much fuel. Just ditch the FMU, tune with the 440s themselves. Maybe upgrade the FPR to an aftermarket. Should do the trick
Old May 30, 2006 | 12:45 PM
impetus19's Avatar
The problem he is having is with his idle though.. the fmu should only affect the fuel curve after boost. Have you talked with rrm about the problem?
RacerX-Ralliart
195
Mar 15, 2021 04:16 PM
Evo Pete MTL
Lancer Engine Management / Tuning Forums
22
Sep 5, 2012 10:14 AM
Evo H8
20
Mar 3, 2009 09:59 PM
lancerrally45
Lancer Aftermarket Forced Induction Tech
188
Mar 13, 2008 07:47 PM
Ozturbo
12
Mar 29, 2005 09:44 PM
