Limiter
Old Jul 13, 2006 | 03:01 PM
grateEVOlover2's Avatar
Limiter
hey, I got a lancer o.z. I love the line but Im a old school racer a 78 camaro with a 350 to be exsactand i'm changeing over to imports i went to check out the top end speed and it stoped at 110 come to find out it was the "limiter chip" what is it exsactly and more importantly how do I remove it?
Old Jul 13, 2006 | 03:07 PM
N1te's Avatar
It's called aerodynamic drag and not enough engine power to overcome it. The lancer isn't speed-governed, it's rpm governed. If you can max out your rpm guage, you can go faster. There is no speed limiter, it's just the amount of power to overcome the drag we have.
Old Jul 13, 2006 | 03:44 PM
thanks. i'm working on geting it turbo charged that should help speed it up a lot but like I said it's a hole new world of cars to me so someone told me i need to repalce the pistons to hold the pressure but that dosent make sence to me sounds like b.s. do you know if theres any truth to that statement? granted i've always worked with v-8's but the pressure frome a turbo can't be that powerfull
Old Jul 13, 2006 | 05:15 PM
crypto's Avatar
Former Vendor
http://www.roadracemotorsports.com/
go there, they sell pistons and rods and also good turbo's
and i think getting new pistons depends on how much psi you use. Any1 with turbo is better of helping you out, but there is the link for where you want to buy turbo stuff.
Old Jul 13, 2006 | 05:27 PM
wiretap's Avatar
There's plenty of people boosting with RRM kits over 200hp, and you don't really need the pisonts/rods unless you plan on pushing it a little much further than what the turbo kit comes with stock. I'm not exactly sure what the different stage kits the RRM kits come with now, but my non-ic t-25 kit runs around 5 to 6 psi according to my boost gauge. Its plenty quick for a little econo-box car. Speedo easily maxes out past what it can read even with the smallest kit they make, which I have. To give you an idea of the performance you gain, I can keep up with my friends stock 03 stang gt convertible (5-speed). Not beat it.. just keep up with it on the rear bumper within a car length or less.
Old Jul 13, 2006 | 11:41 PM
Blacksheepdj's Avatar
Very basic response - at 9 or 10 psi, your stock pistons will melt. At 14 or 15 psi, your stock rods will break.
If you plan on encountering any of those numbers, you know what to do.
Old Jul 14, 2006 | 07:50 AM
sdhes's Avatar
RPW recomends not boosting past 5psi on stock pistons an rods, but from what wiretap said thats pretty good
Old Jul 14, 2006 | 10:43 AM
Maybe it's the exchange rate.
Old Jul 14, 2006 | 02:57 PM
sweet you guys are damn good hay do you know if the TD05 like on the evo is under 5psi becouse I can get a sweet dael on a new one in japan
Old Jul 15, 2006 | 06:19 AM
The turbo doesn't matter. It's what you set the wastegate at.
If it has an internal wastegate (like the TD04 in my basement), you just need to locate a 5 psi spring. If you're running an external wastegate, then you just set that to 5 psi.
The turbo is just the tool. It doesn't determine PSI.
Old Jul 17, 2006 | 01:19 PM
O snap thanks man I didn’t know that I’m new to turbo's in general, I need to really do my home work on them wile I’m saving up enough cash I’ve got the basics down but it's a lot more complicated than the super charger I put on my old camaro
Old Jul 17, 2006 | 03:29 PM
Yeah, it seems like a lot more work.
On the bright side, you could always supercharge the Lancer too. That's an option...
Old Jul 18, 2006 | 08:31 AM
cooool!!!!
Old Jul 18, 2006 | 10:11 AM
crypto's Avatar
Former Vendor
whats the difference between super and turbo charging??
sorry for the noob question.
Old Jul 18, 2006 | 03:43 PM
Turbo’s are powered of the exhaust of the car form the header a super charger is ran from a pulley you add to your belt system turbo’s are more powerful but the super chargers a lot easier to install and up keep the supercharger has been around longer and is usually found in mussel cars if a cheve has ss on it it’s super charged.
