***ECUFlash Now For Base Lancers!***
ok... now i need new map. where can i get it? heres my reading http://www.box.net/shared/j1j7yzk1ch
Well, I've finally found some excellent help in disecting the base Lancer ROM and extracting our maps and coming up with the proper definitions. So far it looks great! Looks like all the base Lancers, Turbocharged and N/A alike can start using this incredible software. Obviously, you need to know what you are doing before you go and start messing with values. You can also have a professional tune/flash your car now! The definitions are in the final review stage, but here are what my base maps look like. This is from my unflashed, OEM, straight from factory ECU:
You can see the huge potential for power. I can't wait to tune my turbo finally and really release the beast!
EDIT:
Okay, after testing it out, this definition file seems to work for me. ECUFlash comes with two definitions for a 2002 Lancer and a 2004 Lancer, which may work for you if you have one of those, but for my 2003 nothing worked. So I needed a new definition file. This is the file you need:
Download 2003 Lancer OZ Rally Definition File (updated 4/24/07)
This is a ZIP file. You can unpack it using software such as WinZIP or 7-Zip. There are two files: the new definition file and the instructions on how to load the new def file. Enjoy!
Here is a great tutorial on how to use ECUFlash: https://www.evolutionm.net/forums/sh...d.php?t=201146
As with anything that isn't factory installed, or installed by a trained professional, you use this software and all supporting files and documents at YOUR OWN RISK! Altering your ECU maps and settings can potentially cause catastrophic engine damage and will surely void your warranty
Please be safe and tune responsibly
EDIT:
So okay, i downloaded this and followed the instructions, but still can't get ecuflash to read from my ecu, I keep getting errors. Is this only for a manual transmission, or do I need to use a different version of Ecuflash? I'm using 1.35.1650
my garage area EVO tuners and I came to them with my 4G94 to be tuned they use the ECU Flash program to tune their customers EVO, in my case they were able to read from the ECU and map it but when we come to write the new mapping an error occurs few seconds after, any advice what the reason for that?
Sorry guys, I posted in the wrong thread....the other thread about flashing an evo rom to a base ecu wasn't working for me...
Okay, so this is for MT lancers, but any suggestions for AT lancers? I'm not even looking to flash just yet, just to read values for fuel and MAF....
I've tried the other thread for flashing base lancers with an EVO rom, but that won't work even to read it on mine...
Just dl'd the master def files, going to see if that helps out... sorry, i need to learn to wait to post until i exhaust all options on my own:-p
I'm from Brazil and I am looking for an ECU ROM for my Pajero Pinin, if someone can help me, I will be very grateful.
Specification Engine: 4G94 SOHC - 131hp
RaceChrome Air Intake
NGK Laser Iridium
Two Fuel Pump 6 bar
11:1 compresssion ratio
NGK Laser Iridium
Two Fuel Pump 6 bar
senate6268
Lancer Engine Management / Tuning Forums
343
May 22, 2026 07:27 PM
mrfred
Feb 26, 2022 06:16 PM
richardjh
120
Oct 6, 2017 08:58 AM
