***ECUFlash Now For Base Lancers!***
Old Jul 3, 2009 | 11:08 PM
  #946
JRR's Avatar
JRR
ok so i have a question after reading thru 63 pages here...
so i went out to my 03 turbo oz and read the rom from my ecu. saved it to my hard drive. did the "mod" that z had mentioned for it to work with the 03. now i go into and open the rom to look at it i get this:
any ideas?
Old Jul 4, 2009 | 12:21 AM
  #947
03lances's Avatar
Wierd no paramters option huh? My 03 ES looks like this when I copied it
Old Jul 4, 2009 | 07:03 AM
  #948
senate6268's Avatar
When you have EcuFlash open, any changes to the files in its folder under C:\Program Files, they aren't reflected until EcuFlash is closed and re-opened.
What is the "mod" that is needed for it to work with an '03? All you need to do is download EcuFlash, copy the master definition list into the EcuFlash folder under C:\Program Files and you're good to go.
Old Jul 4, 2009 | 09:10 AM
  #949
JRR's Avatar
JRR
the "mod im referring to is the one that z mentioned in his first post about there not being anything for a 03 lancer just an 02 and 04. did i misunderstand him?
Old Jul 4, 2009 | 12:23 PM
  #950
senate6268's Avatar
Oh... Things have changed ALOT in the past couple years since support for the Lancer first came about. All you need now is EcuFlash and my master definition file, found here: https://www.evolutionm.net/forums/la...ster-list.html
Old Jul 4, 2009 | 02:17 PM
  #951
JRR's Avatar
JRR
ah ha ic. that makes a little more sence than what i was thinking last night.
Old Jul 24, 2009 | 09:28 AM
  #952
Phoenix*'s Avatar
Truly sorry for the hi-jack...
Is there a thread that provides all definition files for Evo's???
Thanks.
M!
Old Aug 5, 2009 | 05:07 AM
  #953
kmcconn9's Avatar
anybody have a rom for a 2005 lancer es......yea I know, Its my girls car, and I want to see if I can get a little more out of it while increasing MPG
Old Aug 5, 2009 | 11:28 AM
  #954
senate6268's Avatar
Do you need a ROM or a definition file? Definition files are here: https://www.evolutionm.net/forums/la...ster-list.html
Old Aug 29, 2009 | 02:28 PM
  #955
03lances's Avatar
Anyone out there wanting more info on how to use ecuflash and interpreting logs NEED to watch THIS 6 part video series, it is long and VERY informative
Old Mar 2, 2010 | 11:50 AM
  #956
03lances's Avatar
Ok guys so I have run into a problem tuning. My timing maps seem to adjust perfectly with the loads I am seeing in evoscan, however my fuel maps are far from this I am having tremendous difficulty tuning my fuel maps. I have started logging the afrmap which from what I have read is supposed to show exactly what is in your fuel table at any given rpm/load. Mine are not to say the least, anyone run into this? Another thing is EVERY time my afrmap drops below 14.7 (mild to aggresive acceleration) is seems to mirror my 150 load column regardless of what load I am actually seeing leading me to believe my fuel tables are following some other higher load value above my max of 150. Anyone else out there experience this problem and how they fixed it? I am using a evo 399 maf hence my high load values and have found the evos seem to use different loads for there timing and fuel maps also.
Edit: Looking through some of my old tunes with my stock maf I had this same issue, timing maps adjusting fine and fuel maps not.
Old Mar 23, 2010 | 07:22 AM
  #957
Tomcat's Avatar
Good afternoon!
There is beside who nor that XML on table to 9327 ?
(Lancer 4G18 1.6L 2003y)
Can who nor that help with searching for of the tables in IDA PRO ?
http://forum.amadeus-project.com/ind...?showtopic=537 - our forum on cable OpenPort and
EcuFlash, EcuEdit.
Grateful for any help!
Old Mar 23, 2010 | 07:25 AM
  #958
Tomcat's Avatar
Thank you!
Old Apr 13, 2010 | 03:42 PM
  #959
lncrphish's Avatar
quick question: if i unplug my battery will it reset my ecu? will i loose my flash?
Old Apr 13, 2010 | 04:21 PM
  #960
senate6268's Avatar
No. Your flash is in there for good. All that gets cleared is the short term settings that the ECU relearns based on the current conditions the car is in.
