Changing Out the Spark Plugs, Never done it, ?s
Old Jan 29, 2007 | 12:43 PM
TheSeige's Avatar
Question Changing Out the Spark Plugs, Never done it, ?s
Ok so 73k miles later and 4 years of owning my car, i think it is time to change the spark plugs.
ok so is it hard? where are they located? what brand should i get? how many?
2003 lancer OZ 73k miles
no mods to it. help guys
Old Jan 29, 2007 | 12:46 PM
Evoryder's Avatar
sounds like you should stick with the stock Ngks...looks like you don't do much under the hood work...
Old Jan 29, 2007 | 12:55 PM
TheSeige's Avatar
i dont like to put alot of money into something that depreciates faster then anything on earth.
all my money goes into my house. which continually appreciates over time.
dont get me wrong i love my car, but its only here to get me from point A to point B at the recommended speed limit.
Old Jan 29, 2007 | 01:13 PM
Evoryder's Avatar
There is a difference between maintenance and upgrade mods ...
...congrats on the house
Tools: Spark plug puller tool, 4 spark plugs(dealer plugs probably run you around $40 total, cheaper alternatives probably run around $20 out the door) , long extension arm to connect to spark plug puller/socket, wratchet.
Torque to about 20lbs...or tight enough where you can't turn it with two fingers.
Hope you change your oil more often than you do your plugs
Old Jan 29, 2007 | 01:20 PM
TheSeige's Avatar
lol i do, 3k everytime. how often should i be changing the plugs? will a see a big difference in mpg?
Old Jan 29, 2007 | 01:21 PM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
Not to flame or anything but if thats the criteria you needed met, why not a prius?
Old Jan 29, 2007 | 01:27 PM
jakermeister's Avatar
You might need tissue. I needed it to get my spark plugs out. Just stuff it in the spark plug socket and pull up the spark plug. I loved changing the spark plugs on my car because the plugs are very easy to get to unlike my others. Takes about 15 minutes. Look in the how to's.
mac_05evo's Avatar
Plugs for my car run about $7 for all 4 of them. I don't know what plug the regular Lancers use but I think they'd be about the same price. Changing them out is simple, out with the old and in with the new. I've got it down to about 15-20 minutes at a standard pace in my car, and that's checking and rechecking EVERYTHING..
Also, if you don't have a spark plug socket no need to by one. After the plug is completely untightened grab a plug wire and stick it down on top of the plug and just pull it out..
Old Jan 29, 2007 | 01:29 PM
O' and I would get the gapping tool too. Don't pay for pre-gapped plugs that are 5 bucks! Gap the plugs your self and buy yourself a pop afterwards.
Old Jan 29, 2007 | 01:34 PM
Evoryder's Avatar
...just get the plug socket, it's alot easier lol...
changing plugs is mickey mouse. I would invest in a magnetic grabber, for some reason i seem to drop nuts/screws everytime i do my plugs...without fail lol
Old Jan 29, 2007 | 01:36 PM
mac_05evo's Avatar
^+1 on the magnet.. I always tend to drop the little 10mm bolts that hold the coil packs in place...
Old Jan 29, 2007 | 01:39 PM
Evoryder's Avatar
true.
Old Jan 29, 2007 | 01:45 PM
TheSeige's Avatar
prius wasnt 15k
guapoholic
24
Feb 24, 2017 07:47 PM
Ferp
Jul 11, 2016 08:07 PM
inshallah
Jul 5, 2016 07:52 AM
mshilto89
Lancer Engine Tech
Sep 30, 2011 09:14 AM
ralliart 04 21
May 11, 2008 07:10 PM
