Attn: Tuners, i need some help for lancer 2005
Old Sep 19, 2007 | 03:07 AM
Lancer_Egypt's Avatar
Question Attn: Tuners, i need some help for lancer 2005
I have Lancer 2006 4G13 1.3L 90hp engine GLX Egypt (Medial East)
tire size 14" 185 / 65
Automatic transmission
I wish to do engine swaps 4G13 1.3L engine to replace this engine 4G94 2.0L SOHC for various reasons. To produce horsepower readings in excess of 130hp
My question is
should I swap also brakes, suspension, traction, tire sizes ,fuel pump
or i can use min and i just replace the engine only
thanks
Old Sep 23, 2007 | 12:44 AM
there is no help !!!!!!
Old Oct 4, 2007 | 11:22 AM
LithiumX's Avatar
from the little that i know provided everything bolts right up you will need the ecu for the 2.0, you will need the fuel pump from 2.0 or just a bigger fuel pump and any other thing that concerns the engine will be needed as for brakes wheel suspension that is entirely up to you not needed but prob will help but wont stop the engine from functioning depends on how far you wanna take the conversion, the smaller tires with an ecu calibrated for bigger wheel may throw off the speedo a bit not a big deal though
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
ziftawi
Lancer Engine Tech
12
Jul 16, 2008 02:03 AM
