Calling for logs ...
Old Nov 5, 2007 | 09:50 AM
TouringBubble's Avatar
My fuel recommendation thread has sparked the question, "Is the Lancer you logged an isolated case?" Well, I'm sure we'd all like to know. If I'm wrong, you all can point and laugh and go on running 87 in your cars. If I'm right, the community will benefit from it and Lancer drivers will have proof that high octane fuel is better for the car.
So, I need some help getting this info. I'm an Evo guy and don't know many Lancer drivers in the area, so I'm hoping that some of you can provide logs of any Lancer running 87 octane fuel on the stock maps. The thread was about the pre '08 Lancer, but if you have an '08 and the ability to log it I'd love to see those too.
If you would like to provide any logs, just zip them up and post them here, preferably along with the year and trim of the car, as well as a mod list. The logs should include TPS, RPM, octane flag and of course knock count. Anything else is just gravy.
I'm at work currently, but I'll post up the logs I took from the '02 ES in question when I get home. Thanks for the help and I hope this will prove beneficial to the community.
- TB
Old Nov 5, 2007 | 09:56 AM
ambystom01's Avatar
No one will point and laugh, you certainly helped that particular lancer owner and you did raise the question of whether 87 octane is indeed the best. Not sure how much luck you'll have as most of the big tuners (like Alchemist) don't post here that often anymore.
Old Nov 5, 2007 | 10:05 AM
I know no one will point and laugh ... that was just a little light humor. I just love experiments and learning things, so I'm hoping I get a lot of responses to this.
Old Nov 5, 2007 | 02:50 PM
lancerrally45's Avatar
i wish i saved my logs to see you how my 02 lancer ran on 87 when it was stock. haha horrible/a good amount of spark knock. i put 92 in it and all my problems went away.
Old Nov 5, 2007 | 03:11 PM
Redlancer's Avatar
Our Lancer knock a lot with 87 octane... It seen taht Mitsubishi put too much timming advance. (I don't have my log when I was with the stock flash.)
Check in the post 461 of the big thead about Ecuflash, you will find some Evoscan Log of Newfoundlancer
https://www.evolutionm.net/forums/sh...219752&page=31
Old Nov 5, 2007 | 03:20 PM
Redlancer's Avatar
Z_lancer _man do a lot with Ecuflash and Evoscan. The Base Lancer seen too knock a lot with the stock tune and burn a lot of fuel since it run on low octane fuel a lot of time. (Z_lancer_man, Newfoundlancer, Lancerrally45 and me saw this on Evoscan log and maybe other Evoscan user too.)
Old Nov 5, 2007 | 04:00 PM
ambystom01's Avatar
Hmmm that's really interesting, I wonder if this is a lancer only phenomenon or whether all economy cars (ie. civics, focuses, etc.) are like this.
Old Nov 5, 2007 | 04:27 PM
I'm not sure ... but the Lancer has a very ... ummm ... "optimistic" timing map. I've also noticed that there is no low octane fuel map. I guess that makes sense if 87 is recommended ...
Old Nov 5, 2007 | 05:49 PM
ambystom01's Avatar
The lancer should have two maps, a high octane and a low octane. Supposedly the high octane map is the normal one (so tuned for 87) while the low octane map is the "oh my god I'm dying" map.
Old Nov 5, 2007 | 10:13 PM
You know what, you're right. They are just VERY similar.
Old Nov 6, 2007 | 01:09 AM
kungfugirl's Avatar
I found this HILAROUS
hahahaha..
Old Nov 6, 2007 | 05:20 AM
I glad I was able to amuse you.
Old Nov 6, 2007 | 10:44 AM
Tweak3D's Avatar
I actually just purchased evoscan last night and did a test run, using 87 from shell, and got a knock sum count of 4.... this is also n 32 degree weather with only intake and exhaust. just thought I would share.
Old Nov 6, 2007 | 01:24 PM
Redlancer's Avatar
lolll "optimistic" timming map... It's probably one reasons for why the base Lancer don't respond well to the N/A mod. (Compare to Civic or Focus.) They run more often on the Low Octane map (Fuel and Timing).
Old Nov 7, 2007 | 06:15 PM
Sorry it took a while ... here are some logs of the Lancer in question ...
File Type: zip
File Type: zip
