Breaking in a Piggyback
Old Sep 21, 2008 | 01:16 PM
Onkar02's Avatar
how long does it normally take for it to break in has anyone had the same problem as me ? where the car is surging and turning off after its warmed up ? if so how long did it take to fix or what did you do to fix it ?
Old Mar 26, 2009 | 01:52 PM
mtags24's Avatar
What do you mean by breaking in a piggy back?
There shouldn't be any "breaking in period", but there is a learning curve for the ecu. Remember after installing something like this or resetting the ECU (keeping the battery off for 30 min or so) that you must let the car idle for a minimum of 10 minutes and then drive conservatively as it learns. Don't rev high or hit the high way right after install.
Also, if you did the above and are still having problems, odds are you botched the install. Contact RRM
Old Mar 27, 2009 | 09:47 AM
blaze_125's Avatar
Hammer, plyers, screw driver... takes about 30 seconds to "break in".
Most piggy issues are user errors, so I'd say you may have wired it wrong, or your connections aren't good enough.
Old Apr 21, 2009 | 01:32 AM
mxviper73's Avatar
Do you think he has the wrong one installed , cause t looks like the OZ , will not work in the ES. I Think , the difference between manual and auto and V1 &v2 ? which one do you have?
Old Apr 21, 2009 | 04:54 AM
blaze_125's Avatar
I got version 1. This version could be wired to both auto and manual trans as long as you spliced the proper wires.
I don't know about other versions. But I know wiring is usually the problem.
Evo Amzler
May 24, 2016 06:59 AM
Jdunn502
Jan 6, 2011 08:52 AM
philamthebest
Aug 6, 2010 01:36 PM
Justindc2
Automotosports - Illinois
Oct 17, 2006 03:07 PM
Rez90
May 9, 2005 01:14 PM
