Lean under boost!!
Old Dec 25, 2008 | 10:42 PM
  #181
Complink's Avatar
well if your seeing zero knock then maybe
Old Dec 27, 2008 | 11:37 PM
  #182
sykou's Avatar
Originally Posted by 4g94T
im thinking about buying a new walbro, the high pressure GSS342. Is that what everyones is using?
im not sure which walbro i am using right now, as it came with the RRM kit...
Im too lazy to upload pics from my laptop, but my map goes like this:
RPM ---- Timing
3000 ---- 14
3500 ---- 12
4000 ---- 9
4500 ---- 7
5000 ---- 11
5500 ---- 17
6000 ---- 21
6500 ---- 22
still room for advanced timing? BTW this is on 91 octane
Im using the high pressure one. I don't think we'll be seeing fuel pressures high enough to justify the use of the high pressure model... On that note I do have one of the non-high pressure model walbro out of the car now if you need. Pm me
Old Dec 28, 2008 | 02:20 AM
  #183
4g94T's Avatar
I'm gonna pull out my fuel pump first to see which model it is. maybe the pump is going bad or the filter is clogged? And if changing it to a new GSS342 does not fix the problem then I'll buy an aeromotive FPR
Old Dec 28, 2008 | 02:35 AM
  #184
sykou's Avatar
i was told that if it whines its working.... If its clogged then i guess you could check your fuel pressure at the rail.. Should be hella low if its clogged.....
Old Dec 29, 2008 | 05:46 AM
  #185
TouringBubble's Avatar
Be careful swapping out the FPR. Injectors are made to atomize fuel at a certain pressure range. If you go beyond that, you can get inconsistent fueling from poorly atomized fuel.
Yes, most Walboro's whine noticeably.
Old Dec 29, 2008 | 01:47 PM
  #186
4g94T's Avatar
i am using the wrx 440cc injectors. My walbro still whines, and it looks like it is the 255
what is stock fuel pressure at the rail?
i looked over what RC Engineering used for testing when I sent my injectors to them and they used 42 PSI for testing
Old Dec 30, 2008 | 12:22 AM
  #187
sykou's Avatar
thought stock was 38??? may be wrong tho....
Old Dec 30, 2008 | 11:58 AM
  #188
Complink's Avatar
38psi under vacuum. 47-50 at zero vacuum.
Old Dec 31, 2008 | 08:28 AM
  #189
yup, around 48 w/ no vacuum.
Old Jan 1, 2009 | 04:30 PM
  #190
4g94T's Avatar
so how would i install it? with or without the vacuum? on the evo forums some say to set the fuel pressure without the vacuum...
Old Jan 1, 2009 | 04:42 PM
  #191
Complink's Avatar
i believe that is correct.
Old Jan 12, 2009 | 03:41 PM
  #192
Complink's Avatar
did u get the fpr installed 4g?
Old Jan 12, 2009 | 04:37 PM
  #193
4g94T's Avatar
Still waiting on my fittings to arrive =/
I have the FPR and the gauge already...
Old Jan 13, 2009 | 06:33 AM
  #194
I haven't forgotten about this data guys. My customers are up north and are dealing with snow and ice, so no pulls recently. However, a local guy is about to finish his build and I should be able to continue work on this with his car.
Old Jan 14, 2009 | 12:42 PM
  #195
4g94T's Avatar
looks like i have to wait until the 19th for my parts until i can tune again
lancershop takes forever to ship out
