ROAD///RACE Light Aluminum Crank Pulley
Old Apr 15, 2009 | 08:01 PM
4mywifeandkids's Avatar
anyone installed this rrm crank pulley yet on there 04-06 lancer es? Is it worth it?
Old Apr 15, 2009 | 09:32 PM
Complink's Avatar
you might pick up a couple hp to the wheels... your probably better off get an underdrive pulley. but if your looking for substanial gains then save and go turbo
Old Apr 16, 2009 | 12:07 PM
do they make an underdrive pulley for the es lancer
Old Apr 18, 2009 | 10:50 AM
Complink's Avatar
i believe rpw does
Old Apr 20, 2009 | 07:53 PM
fryingpan's Avatar
Where does the underdrive pulley go?
Old Apr 20, 2009 | 09:25 PM
Complink's Avatar
where the crank pulley goes
Old May 15, 2009 | 06:14 PM
snigguh's Avatar
i put one on my 02 oz and it works great seems to have given me less drag on the crank and more ponies down. but be careful NOT to bend the crank trigger censor tab taking the old pully out or putting the new one in. IT sucks trust me. NIGHTMARE!!!! 5 weeks in the shop trying to figure out the problem.
Old Jul 16, 2009 | 08:23 PM
imalancerman's Avatar
Hey what was your vehicle doing in regards to the crank trigger problem? I assume your talking about the crank angle sensor tab? And why would you have to go that in depth to change a pulley? Not to dis just curious. All you gotta do is remove the bolt, pull the pulley with a puller, put the new one on, then tighten the bolt down to spec and it'll suck down the pulley flush. Make sure it lines up with the key on the crankshaft though. Oh and as far as getting a pulley, why spend a ton of money on one of those other ones when you can get an ebay pulley for a mirage and it'll work just as well, if not better. I think there are some threads on here that compare the pulleys and found out the ebay one is actually a really good pulley. I bought one and am thoroughly satisfied with it. Just type in mirage pulley on ebay. They're only like 35 shipped. And they are underdrive. All my accessories still work really well.
Old Jul 23, 2009 | 07:32 PM
numbers5052006's Avatar
seems like a rather inexpensive way to get some extra power off the line. i wonder if it would add some power to the car when driving from a dead stop with the a/c on?
Old Aug 28, 2009 | 10:46 PM
03lances's Avatar
Ok so ya month old thread but what exactly is the difference between a crank pulley and an underdrive pulley? Is the underdrive just a smaller diameter or something?
Old Aug 29, 2009 | 08:08 AM
senate6268's Avatar
An aluminum crank pulley has the OEM dimensions and diameter of the stock pulley. But since it is made from aluminum and not steel there is a lower rotational weight. An underdrive pulley increases the diameter of the crank pulley as well as having it made from aluminum. This causes a lower rotational speed on all the accessory belts, in an effort to free up horsepower.
Old Aug 29, 2009 | 10:13 AM
03lances's Avatar
Oh ok good to know cause I bought an underdrive pulley from another member on here and just thought it was another name for crank pulley
diego88
Evo X How Tos / Installations
Jul 11, 2017 10:31 PM
Rom
Feb 24, 2017 02:20 PM
lancerrally45
Mar 26, 2016 12:26 AM
olik
17
Aug 8, 2005 07:16 AM
tx evo
34
Nov 26, 2003 12:58 PM
