Tuning capabilites
Old Nov 19, 2009 | 12:01 PM
03lances's Avatar
Originally Posted by mtype_06
ok, ok....now that cleared up a lot of thoughts i had about turboing, sounds like i may end up going 4 the Evo 8 ecu, when the time comes for turbo then, at least after i build the engine, since I was just going to buy roadrace's kit and use the piggy while on stock internals...but while n/a, Ecuflash sounds tempting...
So, is datalogging required for Ecuflash tuning, or can i just dynotune with just a wideband o2?
And thanx for the info and assistance so far, guys are epic!
datalogging is required there are alot more parameters you have to monitor besides your air fuel levels, ecuload, timing, rpms, knock, fuel trims, IDC, to name a few.
Old Nov 19, 2009 | 07:33 PM
senate6268's Avatar
oh sh**, i just remembered that im automatic, i cant use the Evo ecu can I???
It's not a simple, direct swap. But I would be more concerned with your auto trans not holding the power you want to make. Auto trans can't hold power past ~250hp or so. You're better off doing a manual trans swap right now to get it out of the way before you get too involved with the turbo and engine work.
Old Nov 20, 2009 | 11:36 AM
mtype_06's Avatar
Actually my auto tranny is the least of my worries, i was just gonna go the levelten way and have my torque converter and other parts worked on so that area of the build is planned 4 when i get to that point
Old Nov 20, 2009 | 05:59 PM
senate6268's Avatar
That ~250hp estimate I gave was WITH a Level Ten converter. One guy here fully built his motor for 300hp+ but got stuck around 250 so he sold his converter and swapped to manual. He made around 325whp after that.
Old Nov 21, 2009 | 11:21 AM
mtype_06's Avatar
With just a converter...but did he do the rest i was planning on doing, like they can fully rebuild the tranny itself, valvebody and everything
http://www.levelten.com/Level_10_Mit...1800-3000s.htm
http://www.levelten.com/Level_10_Mit...a210-3000p.htm
Im just a car ***** lookin 2 make this car into something no one wouldve expected or believed could be done...
Old Dec 5, 2009 | 05:22 PM
bignasty_yagn's Avatar
hey mtype, what rom are you going to use since your an auto? im an auto as well and going turbo in a few months
Old Dec 7, 2009 | 08:06 AM
mtype_06's Avatar
Actually....i really dont know yet, lol! still looking 4 a tactrix cable then i can send my rom to senate for defining
Old Dec 7, 2009 | 08:54 AM
ok when you find out, please post cuz i havent found anything for an auto 02 oz
04mralliart
Sep 6, 2012 07:09 AM
speed4life69
Feb 13, 2011 02:42 PM
boxman
Asian Forum
Dec 10, 2007 01:14 AM
mike1023
Jun 22, 2006 08:47 AM
KevinD
South Region
11
Nov 13, 2004 07:39 AM
