RRM piggy back ecu
Old Nov 20, 2009 | 06:53 AM
03dancer's Avatar
RRM piggy back ecu
does anyone know around how much hp the rrm piggy back ecu gives you? is it worth the 400 bucks...
Old Nov 20, 2009 | 08:24 AM
ClixT's Avatar
depends. the more mods you have, more hp.
i say go ecuflash if you know how to tune.
Old Nov 20, 2009 | 09:13 AM
03dancer's Avatar
how much does ecu flash run? and does it come with like base maps... how much hp do you put down with your car
Old Nov 20, 2009 | 10:14 AM
JRR's Avatar
JRR
ecu flash is free to download but the cable to dio it is like 200 bux for the 2.0 and like 130 or so for the 1.3 cable if you can find them.
ecu flash you do all your own tuning. the only base maps you have are the ones from your rom on the ecu. or if you can find someone with the same rom id that you have then they might be able to help you out.
josh
Ralli_Red
Nov 10, 2015 04:44 PM
NJRalliart
Apr 23, 2010 06:00 PM
05lanceralliart
Apr 3, 2009 12:49 PM
c900t16
Lancer Aftermarket Forced Induction Tech
Aug 18, 2007 05:39 AM
reTro
Oct 13, 2004 08:59 AM
