Curious about Load-Maf-ROM-boost correlation
Old Oct 9, 2010 | 05:47 PM
HornstarBU's Avatar
Please let me know any of the following you can.
What Max load values you see and with what ROM/MAF combination.
What load you see boost start, and what load values you see when boost is maxed at whatever your wastegate is set to.
If you have data (like load when in boost, and max load) on information from when you were using the stock ROM, and then after data from when you switched to an evo rom, or the tephra rom, please include that.
Thank you
Old Oct 10, 2010 | 07:33 AM
Mitsu.kid.02's Avatar
Thank you
seems like i see max load of 98% with stock MAF and stock lancer ROM, boost for me starts around 80% load and stops at 98% at, 5000 RPM, 5PSI. dont know if this helps man, but figured i would pitch in!
mrfred
Feb 26, 2022 06:16 PM
mrfred
Sep 17, 2017 06:11 AM
Raceghost
Dec 14, 2016 12:47 PM
mplspilot
Dec 5, 2016 03:29 PM
mrfred
Sep 28, 2009 01:53 PM
