Problem with my tephra rom
Old Nov 4, 2010 | 06:45 PM
Ozturbo's Avatar
I'm having an issue with my tephra rom, it appears that the MAF tables are not correctly defined.
Can anyone take a look at this and help me figure out what is going on?
Thanks
http://www.mediafire.com/file/61qhbm...20oz%20ecu.zip
Old Nov 4, 2010 | 08:36 PM
Ozturbo's Avatar
[IMG][/IMG]
Here is what the tables look like
Old Nov 5, 2010 | 10:24 PM
03lances's Avatar
Not sure what the problem is here. What maf are you running? The left column is fine and the right column appears to be fine as well
Old Nov 6, 2010 | 12:33 PM
Ozturbo's Avatar
I'm using a 501. entering the values from Senates how to doesn't work you can see in the picture no matter what value I enter it doesn't register, it picks a value close to it like the first is supposed to be 159.2 but it enters 175.5. I'm sure its gotta be a simple fix.
Old Nov 8, 2010 | 02:29 PM
Ozturbo's Avatar
ok, It think the issue is the tephra rom is using a different scaling method. the lowest value i can enter is 175.5 any idea how to do the conversion?
Old Nov 8, 2010 | 07:20 PM
03lances's Avatar
If I remember when I get off I can post a screenshot of my maf scaling table settings
Old Nov 8, 2010 | 08:06 PM
Ozturbo's Avatar
That would be great. Which MAF are you using?
Old Nov 9, 2010 | 12:19 AM
03lances's Avatar
I am running the evo maf but what I am posting it does not matter. This should just show you how to change how your map is viewed and hopefully solve your problem
Ok so this is the definition my maf scaling is using for the right column. You have to go into ecuflash then rightclick "maf scaling" then hit edit map. You will see where is says maf scaling then below that says scalings, mine has unit8 in there where yours has the mafscaling plus mafadder or whatever. Click on that and go all the way down to the bottom and you should see unit8 at the very bottom, click on that to use it and save the settings and see if that helps. The screenshot I have here is for if you do not have the unit8 you can create it using these settings
Old Nov 9, 2010 | 02:42 PM
Ozturbo's Avatar
Hey thanks for sending me your rom. It ended up being easier to just swap some of my stuff over to your rom. Either way my cars now running on the new rom, although extremely rich at idle (10.2-9.8) but all else seems to be pretty good. Ill do some data logging and see what I find.
EGbeater
Jul 23, 2016 08:16 AM
dingus
Jul 10, 2015 08:42 PM
thunderchicken
09+ Ralliart Show and Shine
18
Nov 28, 2012 05:08 PM
jonmorera
Nov 29, 2011 06:41 PM
Jim in Tucson
E85 / Ethanol
14
Apr 11, 2010 08:36 PM
