Community Tephra Tweaking
Old Mar 10, 2011 | 05:24 AM
  #841
Mitsu.kid.02's Avatar
I wanna Speed Density!!!! :-D
P.s. already have the bung in the intercooler piping :-)
Old Mar 10, 2011 | 10:26 AM
  #842
RoadSpike's Avatar
Cool I hope to have a preliminary patch ready this weekend though I guess we'll see if my family can interrupt that process
Old Mar 10, 2011 | 10:34 AM
  #843
:-D
Old Mar 11, 2011 | 09:59 PM
  #844
4g94T's Avatar
Is the AIT sensor required? I was reading that some dont even use it
Old Mar 12, 2011 | 06:36 AM
  #845
I bought it, it was only like 25 bucks why not lol
Old Mar 14, 2011 | 01:03 AM
  #846
RoadSpike's Avatar
Delayed a bit my weekend was taken up mostly with my niece and activities
Not a bad way to go but does delay efforts. I'll try to get some code time on monday night I'll keep you guys posted. Another win is I finally got myself dehooked from one of my RPG games so I'll be more free to do stuff lol!
Old Mar 14, 2011 | 07:17 AM
  #847
Hahaha no prob spiker! ill be awaitin!
Old Mar 15, 2011 | 09:10 AM
  #848
RoadSpike's Avatar
ROM is mostly done still a few things to do like disable the baro ODBII codes and the MAF sensor codes. I'll try to set this rom up the best I can but since this will be the first SOHC car thats gone speed density I wager the VE settings are going to be much different than normal so I'm unsure what will happen.
Old Mar 15, 2011 | 10:24 AM
  #849
As long as my car dont blow up its cool. What do i need to do instalation wise? I have the IAT sonsor, i have a bung on the intercooler piping, how do i wire it up? Also got the MAP sensor ready to go as well
Old Mar 15, 2011 | 10:28 AM
  #850
RoadSpike's Avatar
The map sensor should just plug into the car. The IAT needs to be wired to the car's fuel temp sensor as its the easiest to do without messing up the car's ability to switch back. I don't know what pin the fuel temp sensor is so we can look that up with a pinout digram.
Old Mar 15, 2011 | 12:16 PM
  #851
4g94T's Avatar
If I do switch I think I'd rather get it tuned by Reese Tuning here in San Diego
Old Mar 15, 2011 | 03:20 PM
  #852
4g94T's Avatar
RS, Im not sure if I already asked you this, but can we disable the EGR through the ECU Periphery?
Old Mar 15, 2011 | 03:25 PM
  #853
RoadSpike's Avatar
There are two places one I think disables the test and ignition timing but the other actually stops the actuator. I can't remember if i defined the actuator one for you guys or not but i'm guessing not.
Old Mar 15, 2011 | 03:35 PM
  #854
4g94T's Avatar
This one?
Old Mar 15, 2011 | 03:50 PM
  #855
RoadSpike's Avatar
This one?
Thats one and this table is the other.
<table name="EGR Disable (Set to 0)" address="101d" type="1D" level="1" scaling="uint8"/>
