Community Tephra Tweaking
Old Feb 23, 2011 | 05:36 AM
  #811
Mitsu.kid.02's Avatar
SD SD SD!! and im scared to rev it out to 7k, i dont wanna lift the head??? Also with the auto trans, if i have rev limit at 6,500 RPM will it shift at that RPM, i dont think it will? If not, what do i need to change in order for the transmission to shift that high
Old Feb 23, 2011 | 10:36 AM
  #812
RoadSpike's Avatar
O2 tests didn't work out as planned please just put them back to stock if your using them.
Old Feb 23, 2011 | 11:11 AM
  #813
will doo!
Old Feb 23, 2011 | 03:35 PM
  #814
RoadSpike's Avatar
Can I get someone to log a couple things for me in normal everyday driving and one more spriited run?
8211
820F
Old Feb 23, 2011 | 03:53 PM
  #815
link62's Avatar
8211
820F
will log these on my way to class, so what are these for?
Old Feb 23, 2011 | 04:42 PM
  #816
RoadSpike's Avatar
They are the shift points specifically I want to see how they related to speed in mph. Should be able to draw a conclusion to the speed when the shift points happen.
Old Feb 24, 2011 | 05:15 AM
  #817
I would love to have it shift higher when i romp on it to it pulls longer! the gearing in the auto really sucks
Old Feb 24, 2011 | 07:17 AM
  #818
Also, changing the periphery bits had no effect on the P0136 code :-(
Old Feb 24, 2011 | 04:10 PM
  #819
RoadSpike's Avatar
You know it will probably be easier to just simulate the voltage rather than track down the odbii code hehe
Old Feb 25, 2011 | 07:13 AM
  #820
Good idea, how do i do it? lol
Old Feb 25, 2011 | 09:18 AM
  #821
RoadSpike's Avatar
I'll define a couple tables and make a patch with the rom then you can just copy paste the values into it from the one i did sound good?
Old Feb 25, 2011 | 09:21 AM
  #822
Sounds awesome!
Old Feb 28, 2011 | 07:15 AM
  #823
Any update on the patch spike?
Old Feb 28, 2011 | 09:14 AM
  #824
RoadSpike's Avatar
Didn't have time this weekend i'll get to it at some point.
Old Feb 28, 2011 | 01:55 PM
  #825
k cool thanks spike!
