Community Tephra Tweaking
Old Jan 28, 2011 | 09:49 PM
  #661
RoadSpike's Avatar
Originally Posted by link62
ok cool got it know thanks
Could you test out the knock light in the latest version?
Old Jan 28, 2011 | 09:53 PM
  #662
link62's Avatar
havent yet im taking off to work right now and wont be able to till 6 when im off
Old Jan 28, 2011 | 09:54 PM
  #663
RoadSpike's Avatar
cool
Old Jan 28, 2011 | 10:03 PM
  #664
ClixT's Avatar
Knock Light works but theres a bug.
after starting up the car, the light keeps on flashing for 5 mins or so
then its gonna vanish.
Also how do you log 1byte load? is it the Load MUT 2byte mod?
Old Jan 28, 2011 | 10:07 PM
  #665
RoadSpike's Avatar
no but its defined in recent evoscan versions as a clickable item mut request 41
I'll look into the knock light bug
Old Jan 28, 2011 | 10:19 PM
  #666
ClixT's Avatar
^ ok cool thanks man.
I gotta go to bed too.
Old Jan 28, 2011 | 10:45 PM
  #667
RoadSpike's Avatar
Ok think I got the reason its flashing so much at startup.
I never set the variable for flash time in the rom so its probably initialized with max value and thus taking a long time to run time down.
I'll come up with fix to set the variables to 0 on startup
Old Jan 29, 2011 | 12:04 AM
  #668
RoadSpike's Avatar
Ok this should stop the cel light from flashing on startup
Hopefully it doesn't stop it entirely or bork the other functions
http://www.megaupload.com/?d=637NZMO2
Be careful when testing had to move a function around or two.
Old Jan 29, 2011 | 06:01 AM
  #669
Mitsu.kid.02's Avatar
I gotta figure out why my CEL wont turn on... not good for inspection..
Old Jan 29, 2011 | 08:51 AM
  #670
ClixT's Avatar
ok imma give it a shot.
suggestion, you should use box.net.
no waiting time lol
Old Jan 29, 2011 | 10:10 AM
  #671
03lances's Avatar
Have you determined for sure your cel is not turning on? Like pulling the maf connector and starting it? That would most definately turn it on as long as you dont have a burnt bulb lol.
Old Jan 29, 2011 | 10:29 AM
  #672
Well i "read diagnostic trouble codes" from EvoScan one day and noticed i had a code for "rear 02 low circuit" i dont have a rear 02, and my CEL wasnt on, so im pretty sure the bulb is bad or there is a loose connection back there somewhere
Old Jan 29, 2011 | 10:39 AM
  #673
link62's Avatar
try this lol https://www.evolutionm.net/forums/ev...ock-light.html
Old Jan 29, 2011 | 11:40 AM
  #674
haha i might have to!
Old Jan 29, 2011 | 12:20 PM
  #675
03lances's Avatar
I am not sure if evoscan will read pending codes but like with my scanner reading a pending code means it has the code stored but has not illuminated the cel yet. Just a thought although your probably correct with a malfunction with the bulb whether its bad or loose connection
