Community Tephra Tweaking
Old Jan 28, 2011 | 07:47 PM
  #631
Mitsu.kid.02's Avatar
No probs that i see! here ya go spiker:
File Type: zip
Old Jan 28, 2011 | 07:48 PM
  #632
Originally Posted by RoadSpike
Oh I guess i thought he was asking read it wrong
New rom almost done with knock light and 1byteload
sa-weeeet!! So what does this mean exactly? The startup problem was related to the tephra patch somehow?
Old Jan 28, 2011 | 07:53 PM
  #633
RoadSpike's Avatar
I think i've figured it out why i broke.
Fuel axis variables were never set likely causing the issue.
I believe this kind of patching to the rom is safer so i'm going forward with it.
Old Jan 28, 2011 | 08:08 PM
  #634
Glad you found the likely cause of the issue!! im glad this new one is working very well so far!!
Old Jan 28, 2011 | 08:13 PM
  #635
RoadSpike's Avatar
Ok new stuff this one includes the knock light and the 1byte load preset
Rom:
http://www.megaupload.com/?d=637NZMO2
Lemme know if this hook causes startup issues
File Type: zip
Old Jan 28, 2011 | 08:15 PM
  #636
Rom:
K, brb!
Old Jan 28, 2011 | 08:21 PM
  #637
03lances's Avatar
My aim is linked on this forum you know :P
BTW did you read the article in the ecuflash forum on a beginners guide to disassembly? It would save me lots of writing ;P
I started a thread for disassembly here in the lancer forums and linked to many threads on the subject, (which I have been severly neglecting ) Im sure I've probably read it. I have the full Ida pro and can get into it so it does its own dissassembly but I just cannot grasp this language for some reason.
Ok back on track good news for the autos with all the new patches
Old Jan 28, 2011 | 08:24 PM
  #638
ClixT's Avatar
RS, why is the 1byteload and Knock Light settings all jibberish?
Old Jan 28, 2011 | 08:25 PM
  #639
link62's Avatar
ditto
Old Jan 28, 2011 | 08:28 PM
  #640
No problems with starts :-D Attached log!
Yeah they look off in the way the values are presented in ecuflash spike
File Type: zip
Old Jan 28, 2011 | 08:32 PM
  #641
RoadSpike's Avatar
If you are using the lastest rom i posted it shouldn't be.
I started with a stock rom when i coded this so the knock light settings are completely off.
Also I changed the locations for the knock light settings to better suit this rom so please update xml as well
  #642
RoadSpike's Avatar
Did you log 1byte load? maybe i forgot something hmmmm.
Old Jan 28, 2011 | 08:35 PM
  #643
Yeah i logged 1byte load, do you see it in the latest log i posted? I did use the latest XML and ROM image, i clicked "Yes, to all" to overwrite the old XML
Old Jan 28, 2011 | 08:37 PM
  #644
RoadSpike's Avatar
Looks like i did forget something
MUT table was not set to the correct 41 values.
MUT41 should be 0x8d0b
Posting rom with corrected values.
http://www.megaupload.com/?d=9DKWX9YG
Old Jan 28, 2011 | 08:38 PM
  #645
Spike, that was my bad, i clicked "log 11byte4" not "load1byte" its 11:38 PM here in mass and all this excitment is throwing me off a bit
