Community Tephra Tweaking
Stock ROM was perfect hot and cold starts, so its deff something in the tephra rom thats causing tough starts. We noticed in the tephra the starting load when hot is like 80 its really high, spikers looking into that. Also noticed the iscv steps are off alot, so were going to try to adjust them in the idle stepper lookup table to see if it helps things out. Stock rom hot was like 42 steps, with tephra its like 74 steps or something like that, there off
So I want to try setting the load limit back into the rom.
the load and fuel limits are in the misc category of the rom both are currently set to 0x9 disabling them lets enable them by setting them both to 0x2ba1. I think you have a stock copy so you can just copy them over if you want.
I'll be curious to see if this has any effect. If it does I think we should just try tuning it out because a load limit of 115 isn't that great.
Well I can't really find anything interesting in the rom that can cause this completely.
Well there have been sooo many set backs to this rom I think we are going to start over here and start from scratch and just make this really ultra simple.
We know that the rom works perfectly stock so no worries there.
My plan right now is to implement only big maps so alt maps, knock light, and one byte load wont be availiable at least for the immediate future.
I plan on adding these features in later if required, knock light at the least, if we can make the rom run simply with big maps. Thoughts guys?
