Community Tephra Tweaking
Old Jan 25, 2011 | 01:40 PM
  #526
link62's Avatar
Originally Posted by RoadSpike
Uploaded the new file :/ stupid mistake on my part
http://www.megaupload.com/?d=WB4TJZOV
ill give the new on a try in a bit gotta transfer all my settings over and it took a while last time lol
Old Jan 25, 2011 | 01:41 PM
  #527
Mitsu.kid.02's Avatar
All you have to do is copy the code and paste it in your current xml i think, so you dont have to copy and paste all the settings again
Old Jan 25, 2011 | 01:59 PM
  #528
RoadSpike's Avatar
Spoke with him on the phone car runs hot starts may be semi problematic still course it may be better only time will tell at this point as more testing is required.
Old Jan 25, 2011 | 02:43 PM
  #529
Awesome, i just got home, im going to paste the new code into my xml and see what goes on, ill post a log, gime me a few min!
Old Jan 25, 2011 | 02:51 PM
  #530
My laptop cant connect to the internet (one i use to tune my car) Would you mind posting that fixed code up spike?
Old Jan 25, 2011 | 03:18 PM
  #531
RoadSpike's Avatar
I would prefer this not be hand entered as a mess up here while it wont brick the car it will produce some very odd results. Can't you transfer the file via usb drive or something?
Old Jan 25, 2011 | 04:59 PM
  #532
Yeah give me a min to find my flash drive, i had to go out with the fam for dinner brb!
Old Jan 25, 2011 | 05:08 PM
  #533
Spike should i copy all my new settings over as well? like the injector base/ latency etc the evo specs
Old Jan 25, 2011 | 06:08 PM
  #534
Here are the logs, still unfortunatly its having the same exact issues at the warm start area, maybe its time to go 0 index? Review the logs if you can spiker and let me know what you think, if anything is any different that you notice
Also attached is the vid of the "rough cammed out starts" Dont mind the bumper damage, i got rear ended and its getting covered
http://www.youtube.com/watch?v=_CHEowBDeZ4 when it first starts its got some smoke, then after that when i rev it, its just normal condensation, there was water in the pipe
File Type: zip
File Type: zip
Old Jan 25, 2011 | 09:23 PM
  #535
RoadSpike's Avatar
Less fuel for sure to begin with your starts are so rich that it nearly pegs the wideband to minimum AFR when it finally pops. I would assume with current settings it would start slightly better with a little throttle input.
See if you can't work the ipw down a bit nothing else that i can immediately see seems suspicious.
Old Jan 26, 2011 | 05:54 AM
  #536
Yeah if i give it some gas, it starts easyer, but its still not a good start, and it just makes the car look real bad (as you can see in the vid) Ill try reducing the IPW even more and see what happens, ill brb!
Old Jan 26, 2011 | 07:08 AM
  #537
Still no luck, here are the logs i adjusted the "IPW vs coolant temp" all the way down to .3, also i tried to adjust the "primer enrichment" and the other startup and main fuel settings and no luck :-( its like it wants to start so bad but just cant and it still yealds same results, its like something is blocking it from starting in the first few seconds, but here is the logs spiker
File Type: zip
File Type: zip
Old Jan 26, 2011 | 09:16 AM
  #538
RoadSpike's Avatar
Do you have a log where it was around 6ms or so of ipw during startup?
I'll continue to try and find something that would block it.
Oh and just for amusement without starting the car but turning it on can you hear the fuel pump immediately?
Old Jan 26, 2011 | 09:26 AM
  #539
Ill give that a try and let you know, and ill do another log with IPW at 6ms at hot startup again, the IPW may change in the log, but the results are awlays the same unfortuantly, a rough cranking startup. Ill brb
Old Jan 26, 2011 | 09:43 AM
  #540
I cant hear my fuel pump at all, im not sure if its becuase its super quiet or im not trianed to the sound, but all i hear is the 3 sounds from the key entering the ignition and being in the ACC position and i can hear a loud "grrrrrrrrr" from under the dash, prob the ECU??
