Community Tephra Tweaking
Alrite spike so i changed the IPW's to 6.2ms and here are the logs of the startup, and idle. LMK what you think? Notice how the cold starts the IPW is high and gradually decreases until it starts? On the hot starts it doesnt do this, its just one IPW the whole time it cranks
I cant hear my fuel pump at all, im not sure if its becuase its super quiet or im not trianed to the sound, but all i hear is the 3 sounds from the key entering the ignition and being in the ACC position and i can hear a loud "grrrrrrrrr" from under the dash, prob the ECU??
I had me, along with one of the techs here listen for the fuel pump to turn on and nether the tech or myself could hear the fuel pump when i turned to the key. We tried removing the seat, and coulndt hear it, and also removed the gas cap to listen through there and couldnt hear it there either, hmmm... this along could be the problem? Maybe the pump only tuns on right before the car starts? Not sure..
I can probably track down something in code that preventing the fuel pump from firing if thats the case.
I think it may be mechanical? i have the techs looking at my fuel pump relays and the fuel pump itself, when disconnected releved only 2 drops of fuel with no pressure, so somethings not right here..
If it doesn't come on thats doesn't mean its purely mechanical. The ECU controls when the fuel pump is activated.
Must be something in the ecu that says it doesn't have to turn on the pump when its hot is my guess even though the pressure is gone.
I'm thinking so i'm disassembling the MUT command routine right now to trace back where the ECU turns the fuel pump on I should get some answers sometime just not sure when.
Yeah that makes sense. Im thinking maybe the car starts when cold from the little gas thats in the fuel rail, once it starts the fuel pump turns on an no problems, (becuase when we checked for the fuel pump turning on, the car was cold) And when hot there must be a code somewhere that like your saying might tell the fuel pump not to turn on or a delay time at a certain temp, something of that nature, let me know what you find spike
It will be faster if you can log MUT 9A and 9B for me I can write up a xml if you need it but i think evoscan has it already just look for request 9a and 9b
Spike i just checked out EvoScan and i dont see a request for 9a or 9b im using the latest version of evoscan as well
<DataListItem DataLog="Y" Color="" Display="MUT9A" LogReference="MUT9A" RequestID="9A" Eval="x" Unit="x" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="1000" ChartMin="0" ChartMax="1000" ScalingFactor="1" Notes=""/>
<DataListItem DataLog="Y" Color="" Display="MUT9B" LogReference="MUT9B" RequestID="9B" Eval="x" Unit="x" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="1000" ChartMin="0" ChartMax="1000" ScalingFactor="1" Notes=""/>
Add this to the data.xml in the evoscan folder
