Community Tephra Tweaking
Old Jan 30, 2011 | 06:28 PM
  #706
Mitsu.kid.02's Avatar
i love this new ROM, everythings working great!! i love starting the car when its hot now, i get a good chuckle lol
Old Jan 31, 2011 | 05:07 AM
  #707
Got a question! Im still using the evo settings for the injector base (0x18) and injector battery latencies, but randomly at idle my wide band will go way lean off the charts and you can hear the sound of the engine change when it does this, its like a lower idle. Also when driving my WB reads 14.3-15.6 like normal, however when i come to a stop, WB goes way lean to like 16.8 then slowly adjusts to the normal readings. What would cause this? Is this an effect of my injector battery latecnies being off?
One more thing! When the car is completly cold, i start the car up and it revs to like 3,000 RPM then drops revs and dies, my timing at this point is like 32* idk if that has anything to do with it, maybe ill adjust the low coolant temp timing trim table, but when hot the car starts up np, but bogs down a few times until idle is fixed, almost feels like a bad MAF but i have no codes pending..hmm
Old Jan 31, 2011 | 06:36 AM
  #708
HornstarBU's Avatar
Originally Posted by 03lances
Awesome sounds good.
I know, right? During business hours...that's when RoadSpike and I get our talks in...when we're supposed to be working!
The Evo settings for battery latencies? I thought we talked about this. Those are set for the injector. Evo injectors=evo latencies. Lancer injectors = lancer latencies. WRX injectors = WRX latencies. They are calibrated so that when the car does it's thing and supplies power to the injector, the computer knows how long that injector is going to squirt fuel. If you tell the car it's going to squirt for 1ms, just an example, and it really squirts for .5ms, then you'll have less fuel, and the car goes lean.
Old Jan 31, 2011 | 06:59 AM
  #709
Lol! same here im always on AIM now when i got some serious questions that i know he will have answers to
No not really true. If you change the injector base, along with the injector battery latencies, you change the whole thing. Im not talking about just keeping the lancer injector base with lancer voltage settings.. Spiker and i decided to change this to see if it would make a diff i the IPW vs coolant temp table, it wouldt change no matter what i input when it was hot, it was always the same, but changing the injector base to 0x18 and then multiply the latencies by .625 i belive it was, i was able to adjust the table now, sorta weird, hehe. I think i fixed it just now, the latencies were just a tad off!
Also i was hearing a fluttering sound when getting on the gas, i was like WTF? turns out one of the exhaust mani studs broke where the nut is, so i gotta get a new one and tighten her back up
Old Jan 31, 2011 | 09:08 AM
  #710
RoadSpike's Avatar
Cool looks like you got her worked out .
I think the main reason we got control back of the ipw at startup has something to do with the limp home table.
Old Jan 31, 2011 | 09:11 AM
  #711
Oh yeah, dam should i copy the evo limp home table over as well, thats the only one i didnt copy over
Old Jan 31, 2011 | 09:18 AM
  #712
RoadSpike's Avatar
Can if you want your injectors are stock though so it may be fine for you
Old Jan 31, 2011 | 09:27 AM
  #713
Ok
Old Feb 1, 2011 | 12:48 PM
  #714
nestoledo's Avatar
somebody has the values for the swap of maf 501
tephra is in hz and eclipse in load
Old Feb 1, 2011 | 09:57 PM
  #715
ClixT's Avatar
Its 8 threads below this thread...
anyhow here's the link:
Lancer MAF Swap Step-by-Step Guide
Old Feb 2, 2011 | 03:47 PM
  #716
4g94T's Avatar
This ROM is awesome. Thanks RS!
http://www.youtube.com/watch?v=X1EXPj6ZcwU
Old Feb 2, 2011 | 04:53 PM
  #717
RoadSpike's Avatar
Welcome
You guys wanna try out SD?
Old Feb 2, 2011 | 04:57 PM
  #718
4g94T's Avatar
Just when everything is working fine you give us more things to mess with!
Whats the benefit of SD?
Old Feb 2, 2011 | 05:01 PM
  #719
RoadSpike's Avatar
Assuming all those videos (3) are of your car.
- Smooth as buttah idle with big cams
- No getting under the car when a pipe blows off can just drive home
- VTA BOV if you care for it
- Maf restriction gone... well duh
Old Feb 2, 2011 | 05:05 PM
  #720
4g94T's Avatar
But I like the intimidating idle
SD sounds good!
