Community Tephra Tweaking
Old Mar 30, 2011 | 03:17 PM
  #931
link62's Avatar
log 1 the other is to big
File Type: zip
Old Apr 1, 2011 | 04:32 AM
  #932
Mitsu.kid.02's Avatar
Any updates on the SD tuning?! going to be ready to flash by sunday woo!
Old Apr 1, 2011 | 09:00 AM
  #933
RoadSpike's Avatar
Still tuning lance's car waiting on a log from my last update.
Old Apr 1, 2011 | 09:07 AM
  #934
link62's Avatar
log sent idle is better but when i put it in park it does go to 17 but its not cammy anymore i have all my vac again, it does run a lil rich during light accel and not in boost or at around 0-2psi
also im lance now huh lol
Old Apr 1, 2011 | 09:12 AM
  #935
Is the turbo louder now?!? Cool so looks like ill have my hands full with tuning once i flash the SD ROM!
Old Apr 1, 2011 | 10:52 AM
  #936
RoadSpike's Avatar
Damn it sorry link!
Yeah I'm working on the tables right now. I'm starting to manipulate the 3d VE curve in the direction I think it will go and hopefully we will get really close to the end result we need.
Old Apr 1, 2011 | 08:39 PM
  #937
RoadSpike's Avatar
After playing with link's maps today I think we have some starting settings for everyone that will work out well.
Translated the timing maps over from the tuning session and fuel maps.
Maf settings and others moved over to this rom since they may effect the tune with SD.
The kpa to load table should be close enough to just run.
Fuel map should correlate very closely to desired AFR.
Load limit cap can not be removed with 0x9 please don't change that since its used by the SD system now.
http://www.megaupload.com/?d=UILFAOQE
Old Apr 3, 2011 | 09:16 AM
  #938
link62's Avatar
so i ran a lil test that road told me to do, i disconnected my upper ic pipe and then drove around my block with no problem, felt weird being na for the drive lol when i got back home parked it and still idled at 14.7 like everything was still all hooked up before
sd 1/ maf 0 lol
also after i had another no power problem road the car seems to idle fine now and not lean so i put the latancy back to what they were before and it idle a lil lean but then corrected it self out and now idles fine
Old Apr 3, 2011 | 12:21 PM
  #939
4g94T's Avatar
Found something like a circuit check in the code hopefully this fixes the 403 problem.
<table name="Evap Circuit Test Bypass (Stock 0x4A0B -> NOP 0x9)" address="2A740" type="1D" level="1" scaling="Hex16"/>
This may have a VERY dramatic effect on the car this sub is HUGE!
please be cautious when testing
My car is finally running right so I can flash this.
Anything specific I should look out for? Like not being able to stop the car
Old Apr 3, 2011 | 08:30 PM
  #940
4g94T's Avatar
Looks like it worked! Thanks!
Old Apr 3, 2011 | 08:52 PM
  #941
RoadSpike's Avatar
Found the complete circuit test disable on this rom.
<table name="All Circuit Test Bypass (Stock 0x4A0B -> NOP 0x9)" address="f236" type="1D" level="1" scaling="Hex16"/>
This includes ones that are found before including o2 heaters, tps sensors, and many more. The car will continue to run but will not test for any disabled/open circuits.
Old Apr 3, 2011 | 09:14 PM
  #942
Spiker FTW!
Old Apr 4, 2011 | 01:51 AM
  #943
4g94T's Avatar
So should I just use this instead?
Old Apr 4, 2011 | 08:45 AM
  #944
RoadSpike's Avatar
You certainly could if you wanted.
Old Apr 6, 2011 | 12:22 PM
  #945
STILL slacking... been so busy with other work :-/ hows the tuning coming?? any suggestions for what i first flash this?
