Quick Exhaust Piping Question
Old Nov 27, 2010 | 08:26 AM
Sweetness1892's Avatar
Question Quick Exhaust Piping Question
Before anyone says that i should use the search function, i have and have looked for a while now and couldnt find the exact answer i needed.
My question, does anyone know the stock exhaust piping size for 08 Lancer GTS? Im down to either the magnaflow catback or the greddy se and im not sure if getting the catback will have any extra benefit over the greddy se. I would like a nice sound but nothing major.(I already have the RRM SRI and am sick of that) Im looking more for perfomance gains.
Just looking for a quick answer so if you anyone can help me out that would be greatly appreciated. Thanks!
Old Nov 27, 2010 | 08:52 AM
M@verik's Avatar
The best is a full exhaust. Also its 57mm I believe.
Old Nov 27, 2010 | 09:42 AM
yitzac1990's Avatar
You drive an N/A lancer, for performance gains, the exhaust wont really matter.
Old Nov 27, 2010 | 10:47 AM
Yea, I guess you're right. Does that mean there is any point at even looking at getting the catback? I mean the stock and magnaflow are the same size but will i lose any back pressure?
Old Nov 27, 2010 | 12:58 PM
M@verik's Avatar
It really does matter. Ive built up my 2 NA to give Golf GTI's a tough time. Its just about knowing what to do and not cheaping out on parts. Also custom work is a must.
Old Dec 6, 2010 | 11:11 PM
Panis's Avatar
This.
Buy for sound, or don't buy at all.
Old Dec 7, 2010 | 05:36 PM
p1llar's Avatar
I measured my stock exhaust when I swapped it for my magnaflow catback. The magnaflow piping was slightly larger, I cannot remember what the stock exhaust measured at. I'm thinking it was 2 1/8" at the midpipe.
Old Sep 13, 2012 | 10:12 PM
delly86's Avatar
Good question i have done it, here my setup oem cat with 2.25inch header +cat. midpipe 2.5inch all the way to 3inch muffler. now telling you i feel loss some low end tq, but at highend it quick, but i research you can do some piping bent you will be fine. i more street driving then hwy i need quick take off i drive hard
Old Oct 1, 2012 | 03:36 PM
ATaylor's Avatar
is the tanabe MT any good or even in comparison with these?
Old Nov 5, 2012 | 07:53 AM
ATaylor's Avatar
by getting the full exhaust is the exchanging the catholic converter? wouldnt that void warranty?
Old Nov 6, 2012 | 05:02 AM
timereaper's Avatar
The stock lancer N/A piping is adequate. Just get the axle back exhaust, no need to go catback. You need to preserve the back pressure to avoid losing low end torque for take off. If you drive city all the time or drive CVT transmission, it will keep your power band below 3000rpm most of the time. The lancer engine is a more torque oriented engine compared to engines like the CIVIC SI which is more of HP engine.
Any mods you do to add HP will affect everyday drivability. You need more torque oriented mods.
Also for your application did you know that the piping size is the same for 2.0L and the 2.4L? If it's big enough for the 2.4L with slightly larger displacement, I would think the piping size would be plenty for your 2.0L application.
TxFAkuma
Sep 28, 2015 05:31 PM
gh0stStatus
Aug 5, 2013 05:52 PM
stlgrym3
Aug 3, 2010 08:10 AM
BigBADGSX
Jan 13, 2007 03:48 PM
