help: could not get 100% TPS
Old Apr 16, 2012 | 08:22 PM
revol's Avatar
i've tried logging with evoscan but something is wrong with the TPS..
max it will show 70+ , but pedal pressed all the way..
and in graph it moves up slowly even though im at WOT...any ideas guys..
Old Apr 16, 2012 | 10:15 PM
nj_08_gts's Avatar
Completely normal when logging. Nothing to worry about.
Old Apr 17, 2012 | 12:33 AM
revol's Avatar
ok..thanks...can it be fix? because i cant log the hp and torque...need 80% above for TPS..
Old Apr 18, 2012 | 08:06 PM
nj_08_gts's Avatar
There's nothing to fix - it's not broken. It's a function of the electronic TPS and this exact scenario is mentioned in the factory service manual. A lot of folks use this software, maybe somebody who ran into this can share a workaround? If not, try looking around on the web - there should be plenty of info on this.
Old Nov 26, 2012 | 11:15 AM
wreckleford's Avatar
I have come upon this issue also. Is it just an issue with what the log displays or is the information correct and this is just how the drive-by-wire is programmed? I would think a lot of midrange power could be freed up by having the throttle open more quickly if it is the latter.
Old Nov 26, 2012 | 01:34 PM
LiX's Avatar
LiX
TPS is not logged correctly on Lancers. Use the ThrottleActuator parameter for logging instead of TPS or enable Mode23 for your ROM and build EvoScan definition file for logging.
Old Nov 27, 2012 | 03:01 PM
Thanks LiX. I setup Mode 23 and verified what you are saying,TPS is not logged correctly. With mode 23 the values make sense although TPS does stop at 80%.
jb988
Jul 4, 2016 06:30 PM
GeoMitsu
Jun 19, 2016 04:16 PM
ba109296
Nov 4, 2015 07:02 PM
turboedv6
Aug 29, 2015 06:37 AM
stunt2
Apr 9, 2011 03:54 PM
