03 oz turbo ignition map
Old Jul 10, 2013 | 11:23 AM
mace1890's Avatar
I've recently turboed my oz I'm only running about 7 pounds I have the 94170715 tephra evo rom on it I've changed it some what with the timing to eliminate knock it has gotten much lower but it still seems to knock when I hit boost getting up to about 10 knocks when I'm not in boost it doesn't knock I was just wondering if anyone has a lancer map that they've been using with there turbo and haven't had any knock that I might be able to use and change from there
Posted from Evolutionm.net App for Android
Old Jul 10, 2013 | 11:26 AM
RoadSpike's Avatar
Have you left knock sensor sensitivity stock on the evo rom? If so its probably too sensitive for a stock 4g94 and thats why you see "knock" even out of boost.
Old Jul 10, 2013 | 05:37 PM
mace1890's Avatar
I haven't touched the sensitivity, but I've only got I think 1 to 2 knocks below 100 load it was at like 90 load around 3200 rpm and that's accelerating in to boost
Old Jul 10, 2013 | 08:02 PM
03lances's Avatar
I think some logs would help us to distinguish if its the tune or the knock sensitivity. However if it is still stock I completely agree with RS that you need to adjust those multipliers up some regardless
Old Jul 11, 2013 | 12:25 PM
mace1890's Avatar
I've been looking thru the rom and it has a section for knock control in the section it has -knock load (knock ignored below these values) -knockSum decay timer -knock multiplier low rpm -knock multiplier mid rpm -knock multiplier high rpm -knock adder single gain -knock adder triple gain. Is this where I want to make changes
Live4Redline
Jul 17, 2024 07:09 AM
BigEvo908
19
Apr 10, 2017 10:16 AM
CtSilver03Evo
Cobb AccessPORT
Dec 14, 2016 12:54 PM
stevolution84
Feb 21, 2012 02:26 PM
