ECU problems
Old Feb 10, 2015 | 04:24 PM
TheOtherLancer's Avatar
ECU problems
Okay so I went to have a retune done because the last tune made my speedometer not work. So I went to a new tuner to help me he said he can but then noticed that I dont have a definition files. He found a rom that works just not a def file to match it. My question is if I get an Evo ECU will this fix my problem completely?
Old Feb 10, 2015 | 06:44 PM
Wicked Doc's Avatar
In future it would be nice to give more details on your car...
Seems like you have RRM turbo kit. With evo ecu you would have to throw away rrm piggy back, their fifth injector, install IAT sensor and boost control solenoids to be free of DTCs. Oh and possibly get evo injectors and fuel pump.
Old Feb 10, 2015 | 07:08 PM
I do have the kit minus the fifth injector and piggyback. Sorry I should've explained more. I have evo x injectors with a stock ecu. When I got tuned the first time the tuner only put on an evo x rom and it made my speedometer not work. I'm with a different tuner now and he can't do anything to it cause he doesn't have definitions he has a rom just no definitions to match. We're benching it tomorrow to see if that works and if it doesn't then I'm getting an evo ecu.
Old Feb 10, 2015 | 07:09 PM
And I have a boost controller now lol it was put on 2 days ago
Old Feb 10, 2015 | 11:24 PM
Wicked Doc's Avatar
Benching should work. But as far as I know stock ecu with evo rom will throw crankshaft position sensor code and your MIVEC will not work. The only known way to fix this is to get evo ecu.
Also, did you/your tuner check goldenevo.com? It seems to be back up with definitions.
Old Feb 11, 2015 | 04:49 AM
Were trying the benching today. Yea he usually uses golden when he works with evos but my ecu just isn't working with us. We're figuring it out. Worst comes to worst though I'll buy an evo ecu
Old Feb 11, 2015 | 06:21 AM
anyone know why when evo ecu is in that it throws a cam sshaft sensor and disables MIVEC
Old Feb 20, 2015 | 10:39 AM
I got a evo ecu but my engine didn't start. And all my sensors were going crazy saying I needed to service everything. Any ideas?
Old Feb 20, 2015 | 04:11 PM
Wicked Doc's Avatar
... did you rewrite the VIN?
Read this thread, might help you
https://www.evolutionm.net/forums/la...na-lancer.html
Old Feb 22, 2015 | 03:30 PM
I gave my tuner the attachment so Ill see what he says. But i havent heard anything yet. There closed on the weekends so we'll see.
Old Feb 28, 2015 | 10:39 AM
So I took my car to the dealer and the tech said the car and the ecu aren't communicating with each. It wouldn't even let him put the vin into the ecu. Help
RallySport9
Sep 9, 2013 11:12 AM
get faster
Sep 11, 2005 09:34 AM
NYREDEVO
Aug 30, 2005 07:24 AM
ezhangin
Feb 1, 2005 11:59 AM
