Need to raise rpm!!!!
Old Jul 11, 2016 | 04:03 PM
tacostacos's Avatar
Alright I have a fully built 4g94 that will get a haltech and turbo soon, ( I don't need some 19 year old jacka** telling me I'm going to blow my engine) I need a way to raise the Rev limiter to at least 9k. Cam and valve springs are rated to 10k, rotating assembly is balanced with in 1g
Old Jul 11, 2016 | 09:59 PM
CrAnSwIcK's Avatar
you should be able to set your RPM limit with the haltech...as long as the motor has been built properly, you should be ok at 9k. if you're looking to increase rev limit before installing the haltech then you need to tune the stock ECU, and if you do that, then you may as well skip on the haltech...
Turboholic
319
Jul 8, 2016 08:36 AM
EvoDom
Nov 20, 2008 07:07 AM
MrFairlady
Jun 28, 2006 03:44 PM
bigjhoney
13
Nov 7, 2005 12:29 PM
Turboholic
Nov 14, 2004 11:45 AM
