Reprogramming an ECU DIY Lancer CS 2004
Old Mar 20, 2017 | 09:50 PM
Bell Wallbank's Avatar
so recently did an engine swap over and my mechanics (back yard) but a coil plug and other plug back the front. Only 2 cylinders will start. I got out an auto elleci after blowing 4 coils because the 2 cylinders weren't firing and he said the switched plugs friend the ecu. There is no burn marks on the ecu that I can see of bubbles.
I got a new ecu then was told I will need to reprogram that ecu... apparently it's a very expensive job.
Theres a possibilty that there is a crushed wire in the loom however the auto elleci said it's fine :/
i want to know if i can easily reprogram the new ECU and how?
ANY HELP WOULD BE AMAZING
Old Mar 21, 2017 | 06:24 AM
Nsomniac's Avatar
EvoM Administrator
Moved to the appropriate forum, although I don't know if you gave enough specifics.
Blizzard25
Sep 7, 2014 04:27 PM
Danieln
Apr 9, 2009 04:16 PM
wickedchimp
Apr 13, 2008 02:12 PM
matej
Jan 9, 2007 05:18 AM
