oil ???q's???
Old Nov 11, 2004 | 11:19 PM
lookslikeanevo's Avatar
oil ???q's???
last night kinda cold...out here...but i was a an idle stop and i hear really bad knocks from the engine...i mean really loud...so i get home and there was some oil that had came out othough the oil cap...is that anywhere close to normal?...mods are CAI and Exhaust ...~22k miles..any thoughts?...
Old Nov 12, 2004 | 12:51 AM
sjl6102's Avatar
my lifters tick loudly and sound like a rod knock i live in colorado and right now it is 20 degrees. let it warm for a couple of minutes before you drive. mine goes away when it warms up
Old Nov 12, 2004 | 09:30 AM
thing is that i had already been driving the car for 40+ miles...so the engine wasnt cold
Old Nov 13, 2004 | 03:36 PM
prototypemike's Avatar
that has happened to me once before. i live in fl. and don't have to deal with cold weather but the cause of my problem was that i was low on oil, and that seems to be your problem do to the bad oil cap.
Check your oil!!
Old Nov 13, 2004 | 05:49 PM
Viciouz's Avatar
hearing a knocking sound like that is really bad, could even mean ur engine is about to blow, so next time, just be careful, dont' want ne blown engines cuz of low oil
Old Nov 14, 2004 | 10:01 AM
.L.'s Avatar
.L.
Check your oil!!
ditto. check your oil cap. same thing happened to my buddy's civic. he had a crack in his oil cap, and was losing oil. he caught it on time and replaced it.
Old Nov 14, 2004 | 03:21 PM
i did check my oil the next morning after i let my car sit over night...full of oil....maybe ill got get a new oil cap
Old Nov 14, 2004 | 05:05 PM
rhyzin's Avatar
have you changed your PCV valve? i believe it's every 15k miles, i think. i usually just check it every couple of oil changes. if pressure doesn't pop through that valve, it'll come out your oil cap.
to check if it's bad, take it out and either suck on it or blow through it. one way air won't pass, but will the other way. it's a one-way check valve.
Old Nov 14, 2004 | 11:11 PM
umm wheres the pcv valve?....sorry not good when it come to this
is it easy to replace?
Old Nov 14, 2004 | 11:36 PM
rhyzin's Avatar
it's this piece. its a little to the right of the oil cap. it attaches to a snorkel that comes out of the valve cover on one end and a hose that goes to the intake manifold on the other end. when twisting it off, people get a little scared cuz the snorkel will bend a little. i don't think anyone has broken it yet so i think it's safe. so far i'm on my second pcv valve. stock color is bronze or copper or something like that.
if you blow through the threaded side, it should blow through. if you blow on the hose side, the valve should close and air won't go through. if the valve is "sticky" going from closed to open, it should be replaced.
Old Nov 14, 2004 | 11:49 PM
thanks chris ill do that tomorrow
benIX
May 23, 2017 03:14 PM
Brass
Sep 12, 2016 08:03 AM
adWRXi
Apr 7, 2010 03:31 PM
H'swwEVO
Oct 23, 2009 08:01 AM
WEVO
13
Mar 15, 2006 07:25 PM
