How to tighten the belt
Old Apr 28, 2005 | 11:41 AM
blaze_125's Avatar
My belt has been squeeking for a while on humid days, so I'm assuming it's a tad loose. Can I just make it tighter, or will I need to change it? If I an just tighten it, how would I do it, and what would I need to do it?
Old Apr 28, 2005 | 12:04 PM
Danno's Avatar
I would start by soaping it. Get a bar of hand soap and hold it on the belt when the car is running (not too hard)
In the meentime I will look for my post on this
Old Apr 28, 2005 | 12:05 PM
Danno's Avatar
This should help:
https://www.evolutionm.net/forums/sh...d.php?t=107126
Old Apr 28, 2005 | 12:43 PM
blaze_125's Avatar
Thanks Danno. But what's up with the soap
Old Apr 28, 2005 | 12:48 PM
Danno's Avatar
Its an old trick, works like belt dressing to get rid of squeeky belts
Bar soap only...liquid will make it spin lol
Old Apr 28, 2005 | 02:57 PM
HobieKopek's Avatar
I prefer creamy Italian. Pretty much all my advice is in that link.
Old Apr 28, 2005 | 08:31 PM
Supa tek's Avatar
It could be your tensioner pulley. Pull on your belt near the tensioner and see if theres any play..Also, you should be able to take the belt and twist it 3/4 of a turn. Basically twist the belt so you can barely see the underside and is tight when you near the end. Or you can take a wire brush and stick it under the belt (the side with the grooves), have your car running and spray brake clean on it. Just watch your fingers.
anthonypazsd
135
Apr 2, 2026 12:56 PM
Eno-Evo
14
Aug 4, 2015 08:36 PM
adtalmeda
Lancer Engine Tech
Nov 25, 2014 08:41 AM
didalos
Aug 3, 2013 06:00 PM
vtluu
16
Jan 8, 2011 07:57 AM
